Go to Post I just weighed myself and I have gained two pounds since last Saturday. Thats a sign of a good robotics team. - russell [more]
Unread 29-01-2008, 03:00
AdamHeard's Avatar
Lead Mentor
Calculating Torque required to self Right
I was wondering how to calculate how much torque is required to self right using a single jointed arm. Right now, I'm just doing weight of the robot (~150) at the end of the lever arm to calculate the torque. In reality, less would be required because you are not lifting the entire robot weight (right?).
Anyone know the exact way to calculate this?
Unread 29-01-2008, 07:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Calculating Torque required to self Right
You need to do a summation of torques. Using the side of your bumper/robot that you flipped over as an axis of rotation, figure out how much torque the robot provides on the right trying to flip the robot over, then figure out how much torque is holding the robot down on the flipped side. Subtracting the robot's torque from the flipped side's torque will give you how much torque there is holding the robot down. Then, you can figure out how hard you need to push to flip the robot back rightside up.
Of course, this'll only be a close estimate still, since as the robot rotates back to the upright position (or depending on how far it flipped over) your component of the force of gravity pushing down on your robot will increase and decrease as the angle changes relative to the ground, since as the robot rotates upright more of the force of gravity will be counteracted by the wheels on your robot.
My question is... wouldn't it be better to design the robot NOT to flip easily? Then again, I think you may be on to something this year... I'm thinknig there's going to be a lot of robots crashing into those operator stations as people try to take those turns too fast.
*makes mental note to definitely add accelerometer G-limiter software into teleoperated control loop*
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 29-01-2008, 09:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I would start by caculating the exact center of mass of the robot, then figuring out how far that is located from the edge of the robot where it will be resting as the righting action begins. Do a sum of the moments about one point, then you can figure out the force required to push the robot back upright. This will change as the robot moves, of course...so you probably need to evaluate it in several positions (or figure out a nice mathematical model of the whole operation, which sounds like too much work to me)
Unread 29-01-2008, 16:18
AdamHeard's Avatar
Lead Mentor
-q
We have a pretty low CG and don't plan on tipping; but with the high speeds and the overpass that could easily close line robots, I'd like to know we can get back up.
Calculating relays. VEN Electrical 3 24-04-2007 22:23
calculating distance sur2124 Programming 10 15-03-2006 18:36
Calculating Pneumatic Force Paradox1350 Pneumatics 4 29-02-2004 20:07
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
