Go to Post When I'm asked the question, "What is the most important computer language to learn to prepare me for a programming career?"; my answer is, "Your second one." - Greg McKaskle [more]
Unread 29-01-2008, 20:23
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
IR help
i have absoulutly no idea how to program the IR. can someone post a sample code so i know what it looks like please?
ok, who ate my hot pocket?
Unread 29-01-2008, 20:28
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: IR help
You plug the IR board into the Digital IO and program it just like you would a switch.
if(!rc_dig_in15)
{command1();
Something like that.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2008, 20:29
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: IR help
Are you using MPLab??
Unread 29-01-2008, 20:32
program1's Avatar
AKA: RJ
FRC #2441
Re: IR help
yea, im using MPLab
Unread 29-01-2008, 20:40
popo308's Avatar
AKA: Brent
Re: IR help
yea, im using MPLab
ok so if you just have
if (rc_dig_in01 == 1)
run mottors == XXX
then just
if(rc_dig_in02 == 1)
run motors == XXX
and repeat that for all 4 commands
you just need to tell it was motors to run when you hold the button down...
PM me if you need more help
Unread 29-01-2008, 20:43
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: IR help
I thought it gave you a 0 in programing when you sunk the pull ups of the digital IO to ground. Am I wrong?
Kevin Li
596 - Sciclones
Unread 29-01-2008, 20:47
popo308's Avatar
AKA: Brent
Re: IR help
thats what i thought as well but we hooked ours in and its giving us 1's....
Unread 29-01-2008, 20:48
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: IR help
Yeah the IR gives you 1's
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: IR help
I haven't hooked ours up yet. It could be possible the IR receiver board sinks it to 0 when there is no IR signal. Probably what's happening I guess.
Kevin Li
596 - Sciclones
Unread 29-01-2008, 20:50
popo308's Avatar
AKA: Brent
Re: IR help
I haven't hooked ours up yet. It could be possible the IR receiver board sinks it to 0 when there is no signal. Probably what's happening I guess.
also you are pulsing voltage into the RC where as connecting the pins is a ground to signal connection... that could be why
Unread 29-01-2008, 20:54
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: IR help
What I assume is happening is that the output pins on the PIC on the IR board, is set to 0 which would ground the signal on the RC and give a 0. When it sees the IR pulse it changes the output pin to 1 which is a high 5V. That would give you a 1 in programming.
Kevin Li
596 - Sciclones
Unread 29-01-2008, 20:58
popo308's Avatar
AKA: Brent
Re: IR help
yep exactly
Unread 29-01-2008, 21:59
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: IR help
Here is something I wrote in another thread. It's pretty much completely ready, and will work (as I found out today, because we didn't have power going our IR board and it came back as an error )
http://www.chiefdelphi.com/forums/sh...1&postcount=19
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
