Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Unread 29-01-2008, 22:53
RRA4LIFE2 RRA4LIFE2 is offline
FRC #2595
RRA4LIFE2 is on a distinguished road
ir sensor Board ??????????????????????
We are a rookie team. we do not know how to start up the sensor board. to what type of battery do you connect it, or do you need to buy that battery adapter or what we need help fast!!!!!!
Unread 29-01-2008, 23:05
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: ir sensor Board ??????????????????????
Whoa, calm down there now
There have been a ton of threads posted about this, there are a couple of images that show some of the wiring too.
http://www.chiefdelphi.com/forums/search.php
It will end up being wired to 4 digital ports on the robot and it will end up going into the main battery through one of the circuits. On another thread you posted someone linked you to the page that shows the pin-out of the actual board. Follow that.
There is also a pdf somewhere that shows how the wiring goes with the different panels and the controller etc.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 30-01-2008, 00:22
darkdwarven's Avatar
darkdwarven darkdwarven is offline
AKA: Phantom
FRC #2348
darkdwarven is an unknown quantity at this point
Question Re: ir sensor Board ??????????????????????
I've been searching the forums for remedies to why we can't make our IR Board work. And i've found some that for me have had no effect on the performance of our motors. Right now to test if we can program anything to correspond with the signals that tie IR board reveives/gives, we inserted the following code:
if (rc_dig_in07 = 0)
	ButtonPressed = TRUE;
	if (ButtonPressed = TRUE)
			pwm01 = pwm02 = 127;
That is a function we are trying to put right before our autonomous program. The purpose was to allow the motors to run and if there is an interrupt from the IR Board, the motors would stop for the remainder. The autonomous program works fine without that 'if' statement but doesn't work at all with it. It compiles just fine with everything defined and all. Also, we are working off of port 7 because our advisor read something in the default guide about 1-6 being reserved for more advanced functions?
Any suggestions for resources or troubleshooting options??
Thanks,
Team 2348
I have nothing important to say here, thus I've wasted a few seconds of your life. Isn't that depressing?
Unread 30-01-2008, 08:02
Originally Posted by darkdwarven View Post
This tries to assign the value 0 to the rc_dig_in07 variable. It also has the side effect of never being true. You want instead to test for equality.
In short, replace the = with ==.
Some people use the technique of always putting the constant on the left in a test like this. That way the compiler will notice and complain if you accidentally use a single equals sign.
Oh, and your test is backwards. The IR receiver board outputs 0 when nothing is detected, and gives a 100 millisecond 1 pulse when a valid signal is received.
Unread 30-01-2008, 16:03
Team2002 Team2002 is offline
FRC #2002
Team2002 is an unknown quantity at this point
I was trying the following for our IR board and nothing seems to happen
if (rc_dig_in15 == 1)
pwm_13 = 256;
This was just to test if pressing a button on the remote did anything (the remote was already programmed etc,.)
is there anything wrong that we are doing?
This snippet was placed in the user_routines.c
is that the correct place or should it be under user_routines_fast.c?
Thanks for any help
Unread 30-01-2008, 16:19
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
pwm_13 = 256;
Thanks for any help
I am not 100% positive on this, but here is my thoughts and what to try.
The rc_dig_in7 - 18 are tied high when they are set as inputs. If they are considered active when a switch is closed across them to ground, and the output of the IR board goes high when it is active, then you need to test for a !rc_dig_inxx. So try:
if (rc_dig_in15 == 0)
    pwm_13 = 256;
OR
if (!rc_dig_in15)
    pwm_13 = 256;
Again, I am not a pro at this, just a learner at this point.
BTW, the signal will pulse, so hold the button down.
Unread 30-01-2008, 17:23
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Try this code on a post I made a few days ago. Use MPLAB and add it to the autonomous program. Put whatever you want the robot to do under mode 1 ,mode 2, or mode 3.
http://www.chiefdelphi.com/forums/sh...1&postcount=19
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 30-01-2008, 21:51
    pwm_13 = 256;
Yes. The valid range of values for a pwm output is 0-254. Since the pwm "variables" in the code are of type unsigned char, trying to set one to 256 will actually end up with it set to zero.
You'll need to be a lot more specific about where you put the code. The filename is not really important. What matters is the name of the function in which it appears: Process_Data_From_Master_uP(), Default_Routine(), Process_Data_From_Local_IO(), etc.
Unread 30-01-2008, 22:37
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
no......the maximum pwm value is 256......its an extrema
Unread 31-01-2008, 18:22
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Actually, the maximum PWM value is 255, or 2^8 - 1, which is the maximum value that can be held in 8 bits of memory - the size of an unsigned char. Going above this will cause an overflow problem, where you'll loop around and start at 0 again.
Unread 31-01-2008, 22:46
AKA: Phantom
FRC #2348
We were trying to find a way to program the Robot Cotroller so that when any of 2 inputs receive a signal, it will leave the autonomous code and enter a 'maual' autonomous code. The manual autonomous code would work based on 2 if statements that loop back to the other. The if statements would either say left or right and cotinue until our timer value ran out. Our code in the attached file, only makes the motors pulse for some other direction or go to one and continue straight without any further response. Any problems with our coding? Also does anyone know an easier way of accomplishing the same tasks?
Thanks always for the help,
Team 2348
Unread 31-01-2008, 17:29
FRC #2002
I placed it under Default_Routine() is that the wrong place? I couldnt find a function called Process_Data_From_Local_IO(), in user_routines.c
Unread 31-01-2008, 23:16
If your goal is to test the ability to use IR commands to control motors, that's probably the right place to put it.
But you need to make sure that the pwm outputs you set don't get set to something else later on. You can do that most easily by putting the IR sensing code near the end of the function, so it gets the last opportunity to force the motors to move as you want.
Wiring the IR sensor board govvijay Programming 9 05-02-2008 19:41
Technical Details for the IR sensor board tuzzer Electrical 1 19-01-2008 08:38
How to program ir sensor board?? RRA4LIFE2 Programming 1 11-01-2008 21:47
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
