Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Unread 30-01-2008, 22:42
natalie604's Avatar
natalie604 natalie604 is offline
President
FRC #0604 (Quixilver)
natalie604 has a spectacular aura aboutnatalie604 has a spectacular aura about
Send a message via AIM to natalie604
is this legal?
Is is legal to cut off the threaded attatchment part on a pneuamtic cylinder?
Here's a reference picture:
http://www.andrewsmachine.com/pneuma...ges/bimba3.jpg
Its the threaded part on the right end.
Thanks for your help!
Natalie, 604
Unread 30-01-2008, 22:52
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: is this legal?
The short answer is, no.
Per R92:
Pneumatic components... ...can not be modified except as follows:
- Removing the pin from the rear of an air cylinder is allowed as long as the cylinder inself is not modified.
Do not, for example, file, machine, or abrasively remove any part of an air cylinder.
(I am assuming that you want to use the cylinder as a pneumatic component.) Is there another way that you're looking to mount the cylinder? I can't think of an advantage cutting off the mounting end would have... Maybe we can help you to determine a better/legal way to mount the cylinder?
Bengineer
Unread 30-01-2008, 23:08
natalie604's Avatar
President
Re: is this legal?
we're using two small ones(i dont know the exact stroke at the moment), one on each transmission.
unfortunately we didn't calculate the distance they would take up when actually fit into our chassis, so the backs(threaded parts) interfere with eachother when mounted.
It was a calculation error on our part, i think we might just have to go with a shorter stroke because its too late to adjust tranny plates and it would just be either a horrible mess or a pain(or both) to re-drill holes on our chassis to off-set the transmissions.
no worries =), thank you for your help!
natalie
Unread 30-01-2008, 23:25
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: is this legal?
To over come this problem last year, we had an interface that offset the pneumatic cylinders on each side of the transmission. see here
http://www.chiefdelphi.com/media/photos/27738
(the piston axis and the actual shifting axis aren't in line. it was the opposite on the other side so the cylinders would clear)
but we dont want to do that this year
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 31-01-2008, 10:01
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: is this legal?
natalie
We avoided this problem this year by less than 1/4". We CAD'ed everything to make sure it'd fit beforehand and made our adjustments accordingly. It's pretty easy to make representations of everything in Solidworks/Inventor, as most of the complicated/exact pieces are already made for you on one website or another. For future reference I suppose.
If you shorten the stroke, won't put your gears at risk for not being fully engaged?
GitHub
Unread 31-01-2008, 10:03
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: is this legal?
You could keep the wheels in the same spot and offset the gearboxes by a slight amount so that the pistons no longer interfere. This is what we are doing and I have seen many teams do this.
Is this Legal? Torboticsmember Rules/Strategy 2 07-01-2008 19:28
help is this legal minion master Electrical 7 14-02-2007 13:29
Is this legal IndySam General Forum 19 26-03-2006 20:34
Is this legal Bob92 General Forum 36 24-02-2005 15:10
is this legal? archiver 2001 2 24-06-2002 00:58
