Bumpers
Does anyone have any advice on where to order bumpers and what type of bumpers to order. Any help would be awesome!
Re: Bumpers
The pool noodles may be hard to aquire. Search out the local toy and pool supply store and you should get lucky |
Re: Bumpers
Those are actually "make em yourself"ers. Everything you need is in the instructions right here:
http://www.usfirst.org/uploadedFiles...Robot-RevE.pdf See pages 9 and 10 |
Re: Bumpers
Swimming noodles are being used commonly.
In the K.I.P., I'm pretty sure there is an advertisement for a website on where to buy the noodles. It's either that and/or the fabric that you cover the noodles with. ![]() |
Re: Bumpers
http://www.Seattlefabrics.com/ |
Re: Bumpers
it depends on where you are on where you should get the materials from. I would get them online and just make sure they will arrive early enough to put together.
#7
Re: Bumpers
yea prob going to order from that seattle site
#8
Re: Bumpers
Alright, we've got our bumper materials, etc. and were wondering how everyone else mounts their bumpers (as in, how do you lock the bolt heads to the wood?). Anyone have any suggestions?
#9
Re: Bumpers
We epoxy the bolt heads, which are recessed into the oak plywood; that seems to work well.
#10
Re: Bumpers
hmmm bumpers...As far as I'm concerned we got our bumpers from FIRST (I think).
#11
Re: Bumpers
You only get the design from FIRST. Other than that, it's make your own. |
#12
Re: Bumpers
http://forums.usfirst.org/showthread.php?t=8526 In the past we have made round pockets in the plywood to clear bolt heads on the robot chassis, looks like that is against the rules this year! thanks for spotting that also we've used T nuts, but they do like to pop loose at the most inopportune times...so we were going to try T bolts this year instead, at least if they get loose you can pull them back in without having to disassemble the bumper. It is a bolt and nut system, but the bolt and nut positions are reversed from the design in the Robot Rules. Probably need to ask on Q&A if it would be legal? too bad I can't seem to get access to ask a question. |
#13
Re: Bumpers
Just our look. We just built them yesterday and made holes for bolt clearance.
So would spacers on the bolts be allowed? |
#14
Re: Bumpers
I don't know about your team resources, but last year we used a simple aluminum bracket that was screwed into the wood. The bolts were attached to the bracket, and mounted to the frame through holes in the chassis using wingnuts.
#15
Re: Bumpers
We have used Locking T-Nuts for three years running and have never had any trouble mounting the bumpers to our robot. You have to drill a slightly oversized hole through the bumper and put the T-Nut in the hole from the outside of the plywood before you fasten the pool noodles/fabric to it and pound them in with a hammer. Then you through bolt from your frame/mounting bracket on the robot. Just do a search for T-Nut or Locking T-Nut. We buy ours at Lowe's
| Bumpers | Bob22341 | General Forum | 3 | 03-03-2007 13:34 |
| Bumpers? | 1596guy | Technical Discussion | 2 | 10-02-2007 13:55 |
| Bumpers | great_one411 | General Forum | 1 | 05-02-2003 16:49 |
| Bumpers | archiver | 2000 | 0 | 23-06-2002 22:32 |
| bumpers | Martin | Rules/Strategy | 2 | 13-01-2002 21:51 |
