Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 31-01-2008, 17:57
compwiz2008's Avatar
compwiz2008 compwiz2008 is offline
FRC #2139
compwiz2008 is an unknown quantity at this point
Coding the Gear Tooth Sensor
We need help with the code to the sensor. We have tried many things but cannot get it to function. If you can help it is greatly appreciated.
This is our code
if (rc_dig_in05 > 0) {
counter = counter + 1;
printf("counter %d", counter);
And it still won't count.
p.s. Please show us some code.
Unread 31-01-2008, 18:17
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Coding the Gear Tooth Sensor
First, a question - do you have digital_io_05 set as an input? if not, that may be part of your problem...
Next, i would highly recommend using Kevin Watson's encoder code (see the sticky at the top of the forum) for doing the gear tooth sensors. It needs a small amount of modification, but not much, and it sets up the GTS as interrupts, which help ensure you won't miss information. If your code above is in the main user part of your code, the line will only execute once every 26.2ms, which may or may not fall on a pulse from the GTS. an Interrupt, however, will force the code to be called to increment the counter every time the input changes from a 0 to a 1, so you shouldn't miss any information from the GTS.
Unread 31-01-2008, 19:52
timville's Avatar
timville timville is offline
AKA: Timothy Friez
FRC #1185 (X-Bots)
timville is an unknown quantity at this point
Send a message via AIM to timville
Try ROBOTC... it takes care of handling the encoders as interrupts without any additional coding and is easier to use than MPLab!
2003 - Rookie All-Stars Awards - #1185 (Pittsburgh)
2004-2008 FIRST Volunteer - Ref/Head Ref (Pittsburgh)
2002-2007 FIRST Lego League Volunteer - Head Ref (Pittsburgh)
Unread 01-02-2008, 15:17
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
When you say "Doesn't count", do you mean the output displays only zero, or some other crazyness?
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Gear Tooth Sensor Maria*61806* Electrical 0 30-01-2008 09:07
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
How do you wire the gear tooth sensor? 1594code Electrical 5 12-01-2008 16:24
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Mounting the Gear Tooth Sensor??? blue_crew Electrical 3 09-02-2006 13:53
