Go to Post I may be an engineer, but I am not smarter than a 5th grader. - Josh Drake [more]
Unread 31-01-2008, 23:31
kijj's Avatar
kijj kijj is offline
FRC #2061
Team Role: Electrical
kijj is an unknown quantity at this point
Question Need Help
I have a problem with the default user code for EasyC Pro, the problem is that when i Build & Download the code onto the Robot Controller i plug the Victors PWM, into Digital In/Out port 1 and the other victor's PWM into Digital In/Out port 2 i try to control the robot with the joystick and the PWM light on the Operator Interface turns green if the joystick is moved forward and red if backwards but the main drive motors do not run and the victors LED keep flashing Yellow but if i plug the PWM into the PWM output the motor constantly runs without the LED on and the spike relays work on the relay outputs please help.
Unread 31-01-2008, 23:54
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Need Help
the victors plug into the PWM out's not digital
Unread 04-02-2008, 00:46
kijj's Avatar
FRC #2061
Talking Re: Need Help
Thank you that helpedhttp://www.chiefdelphi.com/forums/images/smilies/biggrin.gif
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
HELP!! i need help starting a new team!! shyra1353 Starting New Teams 18 07-10-2003 17:55
