Go to Post If Andy asked y'all to stand on your head, would you do that, too? ;) - Madison [more]
Unread 02-02-2008, 19:31
Dr Nick Dr Nick is offline
FRC #0501 (The Powerknights!)
Dr Nick has a spectacular aura aboutDr Nick has a spectacular aura about
Send a message via AIM to Dr Nick
Question Dashboard
Hi Everybody,
I was trying to do some debugging with our robot today and attempted to use the dashboard to get some values. To my surprise, I couldn't find the jumper used to set whether you look at RC or OI data and when I tried using the IFI dashboard, it just prompted to change the jumper. Does anyone know if they discontinued dashboard or something this year? I checked IFI's site to see if they had an updated version but the only one I found was dated for 2005.
Anyone know whats going on?
Unread 02-02-2008, 19:44
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Re: Dashboard
Don't use thoose "View OI Data" or "View RC Data" they don't work as the dashboard port is one-way.
To switch between the RC and OI output, move the jumper next to the Dasboard port on the OI.
~David J. Maas (AKA DtD)
Unread 02-02-2008, 19:45
avatarrobodude avatarrobodude is offline
crazy programmer
AKA: Tye Radabaugh
FRC #2068 (Metal Jackets)
avatarrobodude is an unknown quantity at this point
Send a message via AIM to avatarrobodude Send a message via Yahoo to avatarrobodude
Re: Dashboard
I would suggest looking for the jumper again. It is very, very small, and the use of tweezers or forceps is required to remove the jumper. As far as I know, the Dashboard program is still vaild, but some people use the National Instruments dashboard instead.
The jumper is located between the bashboard port and port 1, I do believe. Once again, it is very small, and you will need tweezers or something similar to remove the jumper.
My daily diet consists of: brackets for breakfast, pneumatics for lunch, software for dinner, and plastic tubes for dessert.
Unread 03-02-2008, 11:33
Re: Dashboard
Moving that jumper every time you want to switch between data streams is devilishly inconvenient. We wired up a SPDT switch to a servo connector (i.e. the female end of a PWM cable) plugged on to the dashboard pins so we can just flip the switch back and forth.
That switch has been incorporated into our Operator Console for the past few years. It's very convenient.
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Dashboard? ryan_f Programming 22 14-07-2003 08:37
dashboard archiver 2000 1 23-06-2002 23:06
Dashboard in C/C++ archiver 2000 0 23-06-2002 22:48
