Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 03-02-2008, 13:35
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Splitting the Rockwell Power Distribution Block
Can the Rockwell Power Distribution Block be split into multiple such blocks? I'm not finding a rule that prohibits this. Things I've looked at:
http://www.chiefdelphi.com/forums/sh...d.php?t=61981&
http://forums.usfirst.org/showthread.php?t=8539&
Originally Posted by <R50>
The power distribution block must be directly connected to the APP connector and main
120-amp circuit breaker.
Thanks,
Paul Dennis
1719
Unread 03-02-2008, 13:53
Bluephlame's Avatar
Bluephlame Bluephlame is offline
Controls Leader
AKA: Joe B.
FRC #0145 (TRx)
Team Role: Electrical
Bluephlame is an unknown quantity at this point
Send a message via AIM to Bluephlame
Re: Splitting the Rockwell Power Distribution Block
To the best of my knowledge, yes it is legal although personally, I wouldn't do it until you are 100% certain that you won't need more blocks.
<Patrician|Away> what does your robot do, sam?
<bovril> it collects data about the surrounding environment, then discards it and drives into walls.
Unread 03-02-2008, 13:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You might look at the Power Distribution diagram and think about how you will attach the 3 grey end blocks that you have to two separate blocks, and still cover both ends of each one. I would suggest looking for a Q&A post on this issue, and if there are none, ask yourself.
Unread 04-02-2008, 08:26
The splitting of the block(s) and the cutting of the yellow jumpers were allowed last year as answered in the Q&A. This year's documents do not reflect that as you have pointed out. I would suspect a change is in the works. Please watch your Team Updates in the future.
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
I hope so, that is exactly what we did. We could not find anything that said you couldn't do that either. We split between red and balck distribution. The only thing we did was make sure that we had a gray block on the ends of both din rails. It actually made wiring neater as the reds were on one side of the robot and the blacks were on the other side. Much easier to trace for the inspectors too. I'll keep watching this post to make sure that we are legal or if we need to question the GDC or if someone can show us that it is not legal. Good post!
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Problems With The Power Distribution Block sanddrag Electrical 26 27-03-2007 23:11
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
