Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
Unread 04-02-2008, 20:55
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Distribution Block
Are you forced to use it on your electrical board?
Unread 04-02-2008, 20:57
Re: Distribution Block
Yes. See <R50>.
Unread 04-02-2008, 20:58
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Yes, it is a required part. If you don't need all the segments (and on the positive side you probably won't), it is allowable to remove the excess segments and cut down the yellow jumper.
Unread 04-02-2008, 21:38
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
I would suggest holding off making your Distribution Block smaller until you are absolutely certain that you don't need all of it.
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
Distribution Block File Josh Goodman Inventor 3 12-01-2008 01:34
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
