Go to Post Moral of the story: Keep something you can power on gamepieces at all times. Leaving them "to do their own thing" will only lead to heartbreak. - Ian Curtis [more]
Unread 07-02-2008, 15:58
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
Wiring IR board
For the IR board, would it be enough to let's say to find out if it works by just connecting the pins 1 and 3 to positive and negative? so lets say once i plug it in and power it, can I start calibrating the remote? If it is possible than I think our IR board isn't working the way its suppose to. When we do it the error LED lights once and stops. than when pressing the button nothing happens.
Unread 08-02-2008, 11:00
Re: Wiring IR board
Your assumption is correct.
You just need to power the IR board for it to respond with it's LEDs to training with a remote.
-Hold the white button down
-Add power
-Continue to hold the white button down for several seconds after the first LED lights
-Release white button
-Press one remote key of your choice and hold
-The second LED should light or the first LED should blink.
Here's hoping it works...
Unread 08-02-2008, 16:19
DarKCroNo's Avatar
FRC #2670
Re: Wiring IR board
okay thanks alot! but now when I assign a key to it both the cmd 0 LED is on and the error is blinking, what does that mean??
Unread 09-02-2008, 10:20
SmithWest SmithWest is offline
FRC #2495 (Hamilton West Robotics)
SmithWest is an unknown quantity at this point
Re: Wiring IR board
We had that problem using our RCA universal remote. It was resolved by changing the TV code on that remote. We had luck with an RCA TV code and then realized our 2nd remote was from a Sony TV. We then changed the code on the universal to a Sony code and now both remotes are working as expected. If you are using a non-universal remote perhaps it is incompatible with the board.
Wiring the IR sensor board govvijay Programming 9 05-02-2008 19:41
Need tips on wiring the IR board Bryan Herbst Control System 4 12-01-2008 18:34
pic: Team 668 Wiring Board burkechrs1 Extra Discussion 4 06-02-2007 01:56
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
