Go to Post What I am expecting is the unexpected (what that is I don't know). - mdiradoorian [more]
Unread 07-02-2008, 17:34
penguain penguain is offline
AKA: Barry Preston
FRC #1997 (Stag Robotics)
penguain is an unknown quantity at this point
120 psi
how do you hold the tanks at 120 psi and regulate it down to 60 psi? when i used the norgren regulator it held the tanks at 60 psi and bled off the rest of the air. So how can you do you store the air without bleeding all of it off? I know this is really simple but it is not working.
2007 Greater Kansas City Regional Champions
2008 Greater Kansas City Regional Finalists
Unread 07-02-2008, 17:36
Re: 120 psi
Try putting the regulator on the other way. You might have it such that the 120 psi side is going into what the regulator thinks is the 60 psi side.
Unread 07-02-2008, 18:02
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: 120 psi
EXACTLY! we had this problem i hooked it up backwards(im the electronics and programming guy) the pneumatics guy was being lazy and not coming to class so i had to do it...
that should fix it... so good luck.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 07-02-2008, 21:35
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Re: 120 psi
We had the same problem when we put it on backwards, laziness is not only on your team.
Unread 10-02-2008, 16:50
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Re: 120 psi
can some one post a diagram of this because i am having the same problem the system only goes up to 60 psi
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 10-02-2008, 16:53
dtengineering's Avatar
AKA: Jason Brett
Re: 120 psi
Look for the arrow on the regulator. Think of the air as coming "in" the stem of the arrow and low pressure air heading out the "pointy bit" of the arrow. The two side ports are also low-pressure. You will also notice if you look in the ports on the regulator that one looks different inside than the other three. This one is your inlet.
Jason
Unread 10-02-2008, 16:54
Re: 120 psi
Take your regulator (set to 60 PSI) and turn the whole thing 180 degrees. (Disconnect the tubing first, then reconnect it after turning.) That should solve it.
What happens should be:
120 --> Reg.--> 60
What is actually happening is:
120-->.geR --> 60, which causes the 120 PSI to bleed off to 60 PSI.
Unread 10-02-2008, 16:57
team2061's Avatar
Gilberto Gonzalez
Re: 120 psi
Jason
120 --> Reg.--> 60
ok that makes perfect sence let me go try it and I'll see what happens, thanks again
Unread 10-02-2008, 18:36
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: 120 psi
i made that mistake today
Unread 11-02-2008, 20:22
stndalonecmplex's Avatar
stndalonecmplex stndalonecmplex is offline
Vice President
AKA: Brett
FRC #0815 (Advanced Power)
stndalonecmplex is an unknown quantity at this point
Send a message via AIM to stndalonecmplex
Re: 120 psi
guess what...
our p.s.i limit is
OVER 9000!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Unread 11-02-2008, 20:23
Re: 120 psi
Originally Posted by stndalonecmplex View Post
guess what...
our p.s.i limit is
If you got the pressure over 200 PSI, something is badly wrong. The tubing would probably blow before 500 PSI and almost certainly before 1000 PSI.
Unread 11-02-2008, 20:30
in between teams
AKA: Luke Van Oort
Re: 120 psi
This is mostly irrelevant, but I accidentally discovered last weekend that the regulators can make a noise that is amazingly close to that of a foghorn. The trick is start with one completely closed with some pressure already in the system, then slowly let more pressure through. Just something that might be amusing to try if you're off in the corner working on pneumatics...
Team 1219: 2009 - Mentor
Unread 11-02-2008, 20:41
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Re: 120 psi
The KOP tubing is rated at 175 psi, I believe.
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
Trackball PSI pumbaa2007 General Forum 2 12-01-2008 19:39
Showing PSI in user mode? Billfred Programming 12 02-02-2005 16:52
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
pic: ~850 PSI Robot CD47-Bot Robot Showcase 28 17-05-2003 15:32
