How do you tie this stuff? Can anybody give me a good explanation, or direct me to one? We're totally confused at the "triple pretzel knot" idea
Thanks, computerboi1503 |
Re: Spectra Cable
Team 190 has used Spectra cable many times in the past. The best way to tie it off is to get an Eagle Scout and ask him what knot is best for the job. Really, tieing it is the best way to go.
Re: Spectra Cable
The best knot to use for tying spectra is the bowline.
http://www.hightrek.co.uk/climbing/how2/bowline.htm No matter how tight the rope becomes, you'll be able to remove the knot later. You need a couple of sailors on your team ![]() Also note that if it is high quality spectra the end will not melt well. This is usually how you would keep a polypropolene or nylon line from fraying further after it is cut. To keep it from unraveling, get a bit of shrink wrap and shrink wrap the end of the line. |
Re: Spectra Cable
Now, what application is this knot for? (Note: I am an Eagle Scout.) |
Re: Spectra Cable
If your knot-tying members are really good, they should be able to do a one-handed bowline.*
It may be more difficult with wire than rope, but it can be done. /me perfected the one-handed bowline in a couple days, and still remembers how to do one to this day from way back when I learned it as a Boy Scout. ![]() *The name is a tad bit deceiving. Although you actually use both hands, only one actually does the knot tying, while the other just holds the loose end. Actually come to think of it, I'm not sure if I even remember to tie a bowline the "normal way" anymore. lol |
Re: Spectra Cable
Try using a figure-eight knot making a loop then retracing the knot. with the loose end. This knot has similar properties as the bowline except it has to fail twice before coming undone. It can hold 350 pounds with weaker rope than spectra, and I have trusted my life to it. (Note: I am not an Eagle Scout but am turning in my paper-work to become one next week).
Here is a link on how to tie it. The first section is the one i am describing, and the strongest. http://www.chockstone.org/TechTips/F8Knots.htm |
#7
Re: Spectra Cable
Re: Spectra Cable
In a slick line a double fisherman's knot may actually pull out. |
| competition cable | Idaman323 | Control System | 8 | 20-02-2005 12:25 |
| Breaking Cable | WebWader125 | Technical Discussion | 13 | 28-05-2004 16:44 |
| Y-Cable | CaptainPlaid | Technical Discussion | 0 | 13-02-2002 12:55 |
| CABLE | BOOTY BURGLAR | OCCRA | 2 | 30-09-2001 13:10 |
| Cable Modems | Carolyn Duncan | Chit-Chat | 14 | 06-08-2001 11:00 |
