Go to Post So go out and learn something new, even if it is old. Co-operate in this and you'll get much more out of it. Cheat and you are only cheating yourself. - ChrisH [more]
Go Back   Chief Delphi > Other > VEX
Unread 09-02-2008, 12:16
ttldomination's Avatar
Sunny
Intelitek Loader Press PRGM Button Fail
Hi all,
We've recently upgraded to the latest version of EasyC Pro and when we try to download any code (even the master-code) to the vex controller and we get a dialog box that says:
"To enable download, hold the "PROG" button down until the "PROGRAM STATE" LED is solid orange. Make sure the power is on and the serial cable is connected."
We tried that, but the light never turns orange, it only just sits there flashing green the whole time.
We also noticed that in the IFI/Intelitek Loader it says "FRC" in the status bar when it should say "FTC" (or "VEX", idk) because we're using VEX for FTC...
Anyone know the answer to this puzzling question?
Cheers
-Sunny
Unread 25-02-2008, 19:36
Dalek Dalek is offline
FRC #2194
Dalek is an unknown quantity at this point
Re: Intelitek Loader Press PRGM Button Fail
I had the same problem with my vex microcontroller, so I emailed the Vex support address and they directed me to the “Programming light is always on “ thread on http://www.vexforum.com/forumdisplay.php?f=10. Basically, you need to reload the master firmware.BIN file, then the default firmware.hex file.
intelitek loader/vex USB-serial adapter driver MrForbes Programming 2 07-04-2006 13:37
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
Palm OS Dashboard PRGM Alexander McGee Programming 16 06-02-2004 15:35
Can a student Coach press the Stop Button archiver 2001 3 24-06-2002 02:39
