Go to Post I don't think 330 should have built 330's 2016 robot - Joe Ross [more]
Unread 09-02-2008, 17:36
latonya latonya is offline
FRC #1371
latonya is an unknown quantity at this point
Need a quick answer!!!!
Can we use the 2006/2007 CIM (FR801-001) and cast gear box on this year's bot for a function other than driving the robot? We are already using two of these (CIM + toughbox) to drive the 2008 bot. Also does anybody know the output torque from the 2006/2007 CIM and cast gear box assembly?
Unread 09-02-2008, 18:22
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Need a quick answer!!!!
You can use CIMs from past years, but the 2006 kit gearbox is no longer avalible, and cannot be used. It would probably be best to either use a banebots planetary, or a toughbox or single speed gearbox from andymark, as they have similar outputs.
You can use any legal gearbox for any function, though, provided that that function isn't along the lines of sledgehammer.
Please Only Answer Questions if you know the Answer! Greg Needel General Forum 30 18-02-2010 12:26
MOTOR TROUBLE!! NEED AN ASAP ANSWER!! psycho7 Motors 4 12-02-2006 14:58
I NEED AN ANSWER!!! EVERYONE READ! archiver 2001 2 24-06-2002 01:01
I need a Automotive engineer to answer career questions! archiver 2000 0 23-06-2002 22:24
