Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 10-02-2008, 14:01
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
#25 sprockets with 1/4" bore and a keyway
Does anyone know where we could find some #25 sprockets with a 1/4" bore and a 3/32" keyway? I would really like to stick with the 1/4" bore for another reason specific to our design, but even though keyed parts are harder to find in that size. \
We're planning on getting 1/4" shaft with a 3/32" key slot from mcmaster, but they don't have keyed sprockets in that size. We have a 1/8" key broach, but would prefer not to have to buy a 3/32" broach.
Any suggestions?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 10-02-2008, 14:51
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: #25 sprockets with 1/4" bore and a keyway
Go contact Martin Sprocket and Gear http://martinsprocket.com/.
They should be able to find you some local suppliers and they may have the #25 Sprockets you're looking for with the specific keys and bore.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 10-02-2008, 16:18
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
You may contact some shops in your area and see if any of them can broach it for you if no one has them in stock, also from enco a 3/32" broach is between 20 and 30 dollars, and will eliminate this problem in the future, think of getting the broach as opening up possibilities for you later down the road.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
3/4" bore x 1/2" stroke Bimba Cylinder model sanddrag Inventor 5 16-01-2006 22:14
24" Stroke 1.0625" Bore Piston Legality Yan Wang Pneumatics 4 05-02-2005 09:32
8" wheelchair hubs and 25 tooth sprockets Kirk Stankiewcz Kit & Additional Hardware 9 14-12-2004 19:54
2" Bore Piston Threads Madison Technical Discussion 7 29-01-2002 22:35
