pic: Can you say cheese?
Re: pic: Can you say cheese?
Oh... I thought the blue tint was some kind of pun on the concept of blue cheese....
But the robot looks great. We've been enjoying your videos and photos as you've been building. I'm surprised that you had a weight issue, as it didn't look that heavy. Jason |
I'd say about 69 holes in the drive frame, not counting the back rail and anything inside...
well if your using 1/8" aluminum it would take 419 1/2" holes to lose 3 pounds
Volume of a hole: pi * r^2 * h = pi * (1/4)^2 * 1/8 = 0.0245436926 in^3 Density of aluminum: 0.098lb/in^3 Weight of a hole = volume * density = 0.00240528187 lb Holes per pound = 1 / weight = 415.75 holes |
How much weight would it be since it is pultruded fiberglass? This question ought to slow you down a bit.
#7
The fiberglass weighs about 0.06 lbs/in^3, and it's 1/4" thick on the chassis parts....that's a lot of weight drilled out!
We're sitting around 110 or less so we didn't get to make any lightening holes this year. Quite a change from our rookie robot! |
| pic: Aluminum swiss cheese | flightofone | Extra Discussion | 3 | 20-02-2007 21:40 |
| pic: the complete cheese | falconmaster | Extra Discussion | 2 | 17-01-2007 15:39 |
| How Do You Say FIRST? | looneylin | General Forum | 46 | 02-10-2005 21:51 |
| pic: Double Quater Pounder With Cheese (1251) | sebas2mil | Extra Discussion | 1 | 03-04-2005 20:42 |
| Can U Say Claymation? | archiver | 2001 | 0 | 24-06-2002 00:57 |
