Compiling Robot code...
Hello. Can the robot's code be compiled, and then the resulting complied file be transferred to a system with a serial port to then be transferred to the RC?
Re: Compiling Robot code...
Sure. Are you using easyC or MPLAB? When you compile with either, the compiler creates a .HEX file--you may need to change your Windows settings to see the extension--that can be transfered to a flash drive onto another pc; run IFI loader on that PC and use it to transfer the code onto the robot.
Why not install the compiler on the PC with the serial port? thumbdriving it over seems like a massive pain... Or buy a USB to Serial converter. They can be had for less than $50 if you know where to look; most of the newer ones don't cause problems like the older ones did. JBot |
Thanks for your reply...unortunately, not only is it late in the build to get a USB to Serial converter (6th week - CRUNCH time), but we also don't have a MPLab license to go on the other computer...Again, thanks for the info.
You can install MPLAB/C18 on as many computers as you want.
Things like that cause companies to do what intelitek did--lock down the licensing scheme so far that it is downright a pain to use. |
Getting hold of a USB to serial converter doesn't take much time--it's just a quick run out to Radio Shack and you're set.
| Errors compiling Kevin's new code (pragmas) | Bryan Herbst | Programming | 11 | 31-01-2008 12:50 |
| Robot Timing Code | robotrobot2 | Programming | 8 | 19-01-2008 14:18 |
| Problem compiling Kevin Watson's code | Spencer E. | Programming | 2 | 07-01-2008 00:34 |
| Error in Compiling the Camera Code (B&W Version) | VetteSlick | Programming | 7 | 20-01-2006 20:50 |
| Default Robot Code | lvhsrobotics | Programming | 2 | 10-01-2003 16:55 |
