Go to Post As Shakespeare once said in Julius Caeser, "Cowards die many times before their deaths; the valiant never taste of death but once." - artdutra04 [more]
Unread 12-02-2008, 01:17
bilal1219's Avatar
bilal1219 bilal1219 is offline
AKA: Bilal
FRC #1219 (Iron Eagles)
bilal1219 is an unknown quantity at this point
IR sensor???plz help
Hi, I am the electrical person who is assigned to wire the IR sensor, Now i know that 10 wire ribbon goes on the black output starting from brown as in pin 1. I saw the video and it said the first 1or 2 are connected to 12 volt and 3or 4 is connected to ground.What the problem with me is,They also showed the pwms getting wired and inserted in digital input 1-4, also how to join pwms to the 5-8 wire ribbons. Also, I dun know what is the use of the white 6 pin connector on the centre right side. It would be Great if someone would give step by step procedure.
Please help as soon as possible.
P.S: We dont have mentors,and im the only person who is senior on the team.
Thankx in advance
Bilal Shahid
Team 1219.
<a href="http://www.thebluealliance.net/tbatv/team.php?team=1219" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/1219/FF3300/0066FF/teambadge.png" alt="Team 1219" /></a>
Robots Might Lose But Teams Never Do
Unread 12-02-2008, 01:20
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: IR sensor???plz help
http://www.usfirst.org/uploadedFiles...%20_121007.pdf
that has all the info for the IR board
basically just connect the power to the battery... and the sensor pins to the Digital inputs and you're good to go
Unread 12-02-2008, 08:55
Ignore the white connector. It is used by the manufacturer for loading the firmware on the board's microprocessor.
If you have to ask how to connect two wires together, you probably aren't comfortable soldering and applying heat-shrink tubing. The other immediate option is to use the pale green Direct Mount Terminal Strips from AutomationDirect that came in the Kit Of Parts. Remove the insulation from the ends of the wires, insert them in the holes, and tighten the screws. You can cut the strips to keep only as many terminals as you need.
Unread 12-02-2008, 10:05
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
We used the Direct Mount Terminal Strips that Alan was talking about. We used PWM wires for our IR board. They can be attached to the direct mount and then plugged into the Digital I/O on the RC.
The white wires are for the four signals that come out of the board. Pins 5, 6, 7, and 8. The red wires on the PWMs are positive (5V) and the black are negative. The red and black can all be wired into the corresponding parts of the direct mount terminal strips.
We also wired the power for our board through the 20 amp breaker panel. We will be putting it on a spike later for quick learning.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Visual basic Help plz Jevin H IT / Communications 4 30-03-2007 18:57
help me plz RDD Programming 6 14-02-2007 13:25
Missing Item plz help! Cory Chit-Chat 12 06-05-2003 00:39
Plz help with codec Chris Nowak 3D Animation and Competition 7 18-02-2003 16:15
HELP W/ CONVERTING FILES PLZ... Matt Attallah Chit-Chat 3 03-01-2002 18:47
