Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 12-02-2008, 10:14
PartsMan PartsMan is offline
FRC #9293
PartsMan is an unknown quantity at this point
I am having trouble finding parts
Hi guys. My team wants to build a second robot but I am having trouble finding the parts to buy it. I know they have a PDF with links to buy it but not everything is there. Also one of the stores they link to requires a purchasing commitment of 5,000 a year!
1 power distribution block
3 End anchors 1492-EAHJ35
2 End barrier 1492-EBJ16
4 Terminal block, Black 1492-J16-BL
4 Terminal block, Black 1492-J16-RE
1 maxi block gold plated, 4 position JEF-531D
2 80 mm 12 v fans 412?????
2 8x15 lexan sheets
1 5 x 15 lexan sheet
Controllers GC-1000FR
6 slot circuit breaker 15600-06-21
3 backup batteries 7.2 NiCad
6 pwm wires
6 victors
4 40 amp fuses CB-40A
3 20 amp fuses CB-30A
2 30 amp fuses CB-20A
14 8-32 x 1 inch machine screws and bolts
20 8-32 X 1/2 inch machines screws and bolts
1 120 amp circuit breaker automotive style CB3-SM-120
8 -12 keyang terminals 12015860 (2 terminal housing 412)
one globe motor 12Vdc with drive assembly 409A587
2 Keyang motor 16631023
Unread 12-02-2008, 10:42
Re: I am having trouble finding parts
See The Manual, section "10 - The Kit of Parts", page 4. You will find it useful, particularly the pointers to Innovation First, Inc. and information on purchasing Rockwell Automation terminal block components.
Unread 12-02-2008, 11:07
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
A few things
http://www.terminalsupplyco.com/
The Breaker is Part Number CB3-SM-120
The Gold Fuse Box is JEF-531D
Very nice company to work with.
They have ATO Fuses ( CB-MAX-40 is a Type 1 Circuit breaker that appear similar to the ones FIRST uses)
They also sell all all kinds of bolts but you can get those from just about any hardware store.
My Local Home Depot carries Lexan in various sizes but a google of "Polycarbonate lexan" will get you some other dealers.
PWM wires are just hobby shop wires they use in RC aircraft. Everyone carries them or you might try Tower Hobbies
http://www3.towerhobbies.com/cgi-bin...?&I=LA7482&P=1
motors will be a bit more of a challenge. at leas for another week or two, if they are available normally, they may be tapped out since we're still in build season.
Steve Alaniz
Trouble Finding Part! n_0163 Technical Discussion 3 21-01-2005 00:14
Help!! trouble finding materials! Xufer Technical Discussion 8 20-01-2005 13:48
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
Im am having trouble with the MPLAB hedgehogger Programming 7 19-01-2004 17:37
I'm having trouble sleeping!! archiver 1999 5 23-06-2002 22:38
