Hey we got the IR Board we want to use but we cant figure out how to wire it to the digital in/outs. Can somebody help?
Re: Wiring The IR Board
Sure. Just do a search on CD and look at the documentation on the FIRST Website. This same question has been asked before so I know there is an answer in at least a couple other places.
I can help you with that. What we did was we soldered PWM cables to the IR board. The way to do it is to first cut the male ends off of four PWM cables and solder all of the red wires on the PWM cable to the wires that hook up to pins 1 and 2 on the ribbon cable. Than you want to solder all of the black wires from the PWN cable to the wires that hook up to pins 3 and 4. After that you want to individually solder the white wires to pins 5, 6, 7, and 8. Finally plug the female ends of the PWM cable into the robot controller where you put your digital inputs.
Be very careful though and make sure you use shrink wrap [or electrical tape if you have to] because if you don't you might short something and that would be no good. -morpheous . |
| IR board wiring | Brandon_L | Electrical | 1 | 11-02-2008 15:14 |
| Wiring IR board | DarKCroNo | Sensors | 3 | 09-02-2008 10:20 |
| Wiring the IR sensor board | govvijay | Programming | 9 | 05-02-2008 19:41 |
| Need tips on wiring the IR board | Bryan Herbst | Control System | 4 | 12-01-2008 18:34 |
| pic: Team 668 Wiring Board | burkechrs1 | Extra Discussion | 4 | 06-02-2007 01:56 |
