Go to Post You are beautiful. - Joe Johnson [more]
Unread 12-02-2008, 17:21
1594code 1594code is offline
FRC #1594
1594code is an unknown quantity at this point
Gyro not working
Our gyro used to work, but now it doesn't. We have tried using old gyros from previous years, but they do not work either. Perhaps it has something to do with our code. We are using WPILib:
InitGyro(1);
StartGyro(1);
Wait(2000);
while(1){
printf("Angle %d\r", GetGyroAngle(1));
The output is "0" until the gyro is rotated a large amount (usually near 360 degrees). Then the output is random, ranging from low values into the thousands, with no correlation to the degree of rotation.
Any ideas what our problem might be? Any help would be greatly appreciated!
Unread 12-02-2008, 18:13
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Gyro not working
I'm not sure what type of number that will return, (int, long, etc), but I've had problems printing out longs and the like without %d. Check what the function returns.
Sorry, I'm not sure about this one.
Unread 12-02-2008, 18:16
fstumpo's Avatar
fstumpo fstumpo is offline
Question Everything!
FRC #1640 (SAB-BOT-AGE)
fstumpo is an unknown quantity at this point
Try typecasting:
while(1){
printf("Angle %d\r", (int) GetGyroAngle(1));
gyro not working johnsmith11111 Programming 4 14-02-2008 17:13
Gyro not working in Autonomous? kaszeta Programming 7 11-02-2006 01:28
CMUCam not working Inverted Programming 10 04-02-2005 19:32
Radios not working... E Jones 234 Control System 3 21-01-2005 21:58
