Go to Post What? No Poof balls as pillows? Phfff. Amateur. :p - artdutra04 [more]
Unread 13-02-2008, 17:12
pdelbarba pdelbarba is offline
FRC #2641
pdelbarba is an unknown quantity at this point
Red face Yaw rate sensor help
I'm trying to implement a yaw rate sensor for the purpose of keeping our mechainum (or however you spell it) wheels from driving in random directions. The issue is that I have no clue as to how to extract a value from robotc. Is this digital or analog and what type of 'sensor' is this in robotc.
Thanks
Unread 13-02-2008, 19:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Yaw rate sensor help
The YRG is an analog sensor. If you're interested in knowing your relative heading, then you want to use it as a gyro. If you want to know your rotational velocity, then you want to just get the raw value. Use the sensor wizard to set it up. Post on the RobotC forum if you're still having trouble, or drop one of your friendly Senior Mentors a line.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Yaw Rate Sensor Drift? phrontist Control System 13 19-08-2004 10:55
Yaw Rate Sensor.. Questions yruhere Programming 9 01-02-2004 10:52
Yaw Rate Sensor gburlison Electrical 23 21-01-2004 09:08
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
