Go to Post You know you're addicted to FIRST when to you: 4's company, 5's a crowd, and 6 is someone off-sides. - Tetraman [more]
Unread 14-02-2008, 01:10
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
CIM Noise
So, we have two CIMs hooked up to an AM ToughBox. This is driving a pulley with a cable, lifting up a lift. Lots of torque, but not too much.
The first time you lift the lift, it goes up nice and smoothly. No motor noise.
The second time you lift the lift, the motors start making a terrible vibrating sound, almost as if they are being stalled. Increasing the speed reduces the noise, and at full speed there is no noise (but we would NEVER want to lift our lift at full speed.)
If you let it sit for about 10 minutes (I'm assuming the motor 'cools', or something to that effect), and try it again, on the first lift, there is no noise again.
Any Thoughts? (I can provide torque values if required.)
Jacob
Unread 14-02-2008, 08:06
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: CIM Noise
Are you sure that the vibrating is an issue? We have a 4CIM drive train and it makes a lot of noise on one side due to our plates being different sizes, so the gears don't mesh as well as they should. You may want to check that.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 14-02-2008, 08:12
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: CIM Noise
It very well could be heating/cooling. The AM Toughbox has a lexan backplate, and plastics are known for having high coefficients of thermal expansion. It could very well be that you're heating that plate up.
If you continue to have problems, you can try making a new back plate for the Toughbox out of a stronger material (like a plate of 1/8" (or holey 1/4") aluminum).
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 14-02-2008, 08:30
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: CIM Noise
-q
If that's the case the friction for the heat must be coming from the gear boxes, By the time the CIMS get hot on the outside, they're really hot on the inside.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-02-2008, 08:44
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: CIM Noise
The problem may not be in your motors.
Make sure there is a low amount of friction on your sliding device for upward travel. If it is metal on metal white lithium grease would work well, but requires maintenance and can be messy if you over apply.
If it is 80-20 with those nylon slide plates (which my money for no apparent reason is on) you have to check and see what will affect the nylon. I think the white lithium would work there too.
All speculation
all assumptions
but one big hunch
won't hurt to check it out
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 14-02-2008, 11:34
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: CIM Noise
Are the two Victors driving the CIMs driven by a Y-cable? You might try calibrating the Victors again using the same joystick to make sure the motors aren't backdriving each other a little bit. I say this because PWM variability can be the worst at the lower speeds, and you said it vibrated more at lower speeds.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
microcontroller picking up noise? sciguy125 Electrical 24 18-09-2007 22:14
PWM Signal Noise? Danny Diaz Electrical 3 28-01-2007 17:02
Noise Makers!!!! skitz547 Chit-Chat 26 02-02-2003 00:30
Noise Emission Problem... archiver 2001 3 23-06-2002 23:30
