Go to Post Please Note: Elgin is still wearing his safety glasses. Practice safe Dewing. - JohnBoucher [more]
Unread 14-02-2008, 12:34
jfrank's Avatar
jfrank jfrank is offline
FRC #2668
jfrank is an unknown quantity at this point
Question joysticks
if you are going to use two or more joysticks how do you define the second joystick's "buttons"
how do you make / change definitions of "buttons" on the joystick(s)
EX: top, fire, etc...
ps.
model # P-35221
gamepro gear
prostick
Unread 14-02-2008, 12:37
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Re: joysticks
The seconds joystick buttons are the same as on the first, except instead of p1(ex. p1_sw_trig for trigger) its p2 (ex. p2_sw_top). If your saying you want to make your own definition for them, use define. At the top of your file, put #define port1_trig p1_sw_trig;
When you put code in using port1_trig, it will be the same as if you put in p1_sw_trig.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 14-02-2008, 12:47
jfrank's Avatar
FRC #2668
Cool Re: joysticks
thanks, but how to you make a new definition if a button was never defined in the first place?
Unread 14-02-2008, 13:03
Re: joysticks
I suspect you may be using EasyC Pro and the answers for that are quite different than the answers given here for MPLAB.
In MPLAB all the joystick buttons (and more) are already defined for every Operator Interface joystick port.
For example, all the joystick triggers are:
p1_sw_trig
p2_sw_trig
p3_sw_trig
p4_sw_trig
Unread 14-02-2008, 13:09
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: joysticks
All the definitons to inputs are made in ifi_alliases.h. Take a took in there and add another definition if you want. Available ports are already defined though.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 14-02-2008, 13:13
Re: joysticks
I suspect thats what the original question was. Thanks for clearing it up
Unread 14-02-2008, 13:44
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Re: joysticks
I believe all of the pins on the OI ports already have some sort of definition...
To see what names are given to different pins, you could check here.
If you're using the USB chicklet, I think you have to tell it what buttons you want corresponding to what...there should be instructions for that specifically, though.
Joysticks.... Moloch Control System 12 11-03-2005 20:58
Joysticks LBK Rules Control System 2 12-01-2005 20:38
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
joysTICKS edomus Control System 7 01-02-2004 00:51
Joysticks Neal Probert Technical Discussion 16 08-01-2003 21:59
