Go to Post We are just helping to keep Home Depot from going Bankrupt :D . - E. Wood [more]
Unread 15-02-2008, 01:48
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Retrieving Code
Hello, I was curious if there was anyway to pull code off the RC? Or if anyone has a program they made that can do it??\
Thanks in advance,
POPO
Unread 15-02-2008, 07:54
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Retrieving Code
Check the IFI site, there is a tool.
However, you're only gonna get (at best) a functional binary, you won't be able to get the source.
Unread 15-02-2008, 08:24
Racer26 Racer26 is offline
Re: Retrieving Code
Felix is correct. You can get the hex file back off of it using a tool from IFI, but that won't get you the C source that was used to make it. You might be able to get a disassembler for that code, but that will still only get you PIC18F assembler code.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
WRRF Code wrapper for Innovation FIRST Code FotoPlasma Programming 0 02-02-2004 19:28
