Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 15-02-2008, 10:15
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Inventor animation help
does anyone know how to use the animation feature on Inventor 2008? I need some help with placing constraints on some of the robot parts and then animating them.
Unread 15-02-2008, 14:48
grsnovi's Avatar
grsnovi grsnovi is offline
Autodesk Inventor Team - Portland,
AKA: Gary R Smith
FRC #2542
grsnovi will become famous soon enough
Re: Inventor animation help
Derek,
You want to make sure that all of the parts of your robot are properly constrained in the assembly.
There are then a number of ways to do animations:
1. You can animate a single constraint using the DRIVE CONSTRAINT option. If other parts depend on the part that moves when you drive the constraint, they will also move. This technique is usually used to view a simple mechanism movement.
2. You can create an IPN file that will (usually) animate an explosion of your assembly so you can see all of the parts and how they go together.
3. You can use Inventor Studio to animate motion, visibility and other "events" using a timeline that will allow you to show things happening according to a "script" of things that you want to happen over that span of time. Studio allos you to animate multiple events which occur simultaneously or which overlap. Most animated event within Studio rely on the constraints you placed in the assembly however some events can be animated that ignore assembly constraints if that is what you need.
4. Inventor Professional also provides a Dynamic Simulation module that would allow you to animate an assembly that took into account friction, gravity, etc... it is likely beyond the scope of what you might want to start with (however there is a tutorial supplied with Inventor that would allow you to explore Dynamic Simulation).
Unread 15-02-2008, 15:24
D_Price's Avatar
Engineer/Mentor
AKA: Derek
ok thank you so much for the help
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
