Go to Post Some may call it an obsession and they may be right, but I call it a huge learning experience. - Elgin Clock [more]
Unread 16-02-2008, 16:25
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
URGENT HELP: IR board TRAINS but does not RECIEVE
I checked the voltage regulator, it's at +4.99V, and everything is wired correctly. It was working until about 20 minutes ago, and we've made NO changes. Does anybody know how to fix this?
Thanks!
Team 518 Home Page
Unread 16-02-2008, 16:34
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: URGENT HELP: IR board TRAINS but does not RECIEVE
Thanks!
Check Team Update #10. We're having the same problem. Not sure how to fix it yet. But to fix the initial cause we're thinking of using a spike in between the breaker panel and the IR Sensor.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 16-02-2008, 21:15
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
TEAMS THAT ARE ABLE TO FLASH THE IR BOARD'S ONBOARD PIC (using an ICSP programmer)
CAN FIX THIS PROBLEM BY REFLASHING IT WITH IFI's HEX FILE
I have attached the HEX file I was sent by Mr. Greib
*I have no copyrights of it
*I am not responsible for anything!
I was also instructed to make sure the ICSP reprogrammer's pin1 is connected the board's pin1 on the white ICSP connector.
Ran.
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 17-02-2008, 12:08
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
We had the same problem. The board has power, the regulator is good, but it won't run. I have a Microchip ICD2 programmer and downloaded the HEX file, and programmed the device. Verification failed at first, because I believe code protect is on. I also got this message "MPLAB ICD 2 does not support programming this device if both the internal oscillator and internal MCLR are selected. You may continue programming, but you are encouraged to cancel, reconfigure your device, and try again". I erased the device programmed it again and it works. I also removed the "code protect" configuration bit so that the programmer could verify the code.
It works!
Have to go put the board back on and get this thing in the crate!
Brian
Brian K
Team 1225 Robotics Mentor
Unread 17-02-2008, 15:16
3dude_2231's Avatar
in fact I have recieved a message from Bob (Greib),
saying I might encounter those problems if I use ICD2
Unread 17-02-2008, 15:24
Larry R Larry R is offline
FRC #1258
Team Role: Electrical
Larry R is on a distinguished road
Send a message via MSN to Larry R
I too had good luck with reflashing the IR board. I received a lot of valuable hints from Bob Grieb. I used an MP Labs Serial Programmer and the MP Labs software that goes with it. I had to use jumpers between the IR board and programmer: Ground, MCLR, PGD and PGC. My programmer does not have an ICSP standard cable. I powered the IR board from a separate 12v supply. I flashed (erased/programmed) Firstir.hex. 3 seconds later I had a working IR board.
I set the programmer software to erase before programming and had no problems at all. This was Bob's suggestion. The board now is back to working!
My next task is to add a power switch and instruct the team on how to power up the board so this doesn't happen again.
Larry
Electronics Mentor
Team 1258
Unread 20-02-2008, 20:31
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Many thanks to all who have helped solve this problem. I put together all the files for the solution (WinPIC, Hex code, etc) into a single .zip file for folks to download.
Let's see everyone up and running during Hybrid mode!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
IR Board will train but wont recieve outside train mode gam3fr3ak1 Electrical 1 16-01-2008 15:53
Drive Trains-help bookworm2011 Technical Discussion 5 21-12-2007 02:48
frc_camera not working but labview does Issues Programming 7 18-01-2006 19:23
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
not robotics, but help would be appreciated pryoplasm Electrical 26 02-06-2004 07:14
