Go to Post "I have cut this piece 4 times and it is still too short!" - Betty_Krocker [more]
Unread 16-02-2008, 19:37
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
what is the eeprom write bandwidth?
If I want to fill the eeprom with data in a period of 15 seconds, that's 1024/15 = 69 bytes per second. I know that the bandwidth is less than 38 bytes per second, otherwise eeprom.c would not need a queue.
I'm trying to size the queue to not overflow at 69 bytes per second. I guess I could make it 1024 bytes (but is that itself a problem?).
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 16-02-2008, 20:31
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: what is the eeprom write bandwidth?
If you're referring to my code, you can also call EEPROM_Write_Handler() multiple times per 26ms loop. Just be aware that
EEPROM_Write_Handler() takes about two milliseconds to execute.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-02-2008, 23:47
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
-Kevin
I am using your code (thanks!). And if had taken a moment to look at the write handler I would have seen that the queue size is decremented every call. (I had imagined that the eeprom write operation was asynchronous, and the write handler was just periodically checking to see if the current byte was done.)
I think that means that I can add a second call to the write handler and get a write bandwidth of 38 * 2 = 76 bytes per second, which is (on average) fast enough to fill the eeprom during autonomous (15 * 76 = 1140 > 1024). The only question that remains is whether I will overrun the queue buffer with a burst. I guess I'll just have to try it.
Hi to all Readers, wondering what to write in my first message NickolasVanily Chit-Chat 3 30-12-2006 23:18
Extra Bandwidth on the OI? mechanicalbrain Programming 4 06-03-2006 16:30
You write the forum rules Ken Leung CD Forum Support 8 17-01-2005 11:18
read/write EEPROM on 18F8520 WizardOfAz Programming 39 22-03-2004 13:32
What program should I write? rbayer Programming 24 03-10-2003 20:07
