Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 17-02-2008, 16:02
theprogrammer theprogrammer is offline
FRC #1982
theprogrammer is an unknown quantity at this point
GTS confusion
our program compiles without error but when we try and use Get_Encoder_1_Count(), we get a programming state error. Anyone having similar problems or had similar problems and knows what im doing wrong?
Unread 17-02-2008, 17:33
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: GTS confusion
Make sure you have followed the instructions in Kevin Watson's readme, assuming you are using that code. Usually the interrupts are not enabled in one of the headers. (Or does that just result in a returned 0 value...?) Either way, make sure the readme steps are followed.
old GTS seanl Electrical 0 09-02-2008 16:30
GTS Code windell747 Programming 5 07-02-2008 00:29
GTS strange behavior iwdu15 Programming 6 01-02-2007 18:46
GTS Counting gnirts Programming 13 21-04-2006 21:15
GTS code Problems caderader Programming 8 13-02-2006 19:23
