Go to Post I believe it is in the spirit of the game is to score more points than your opponent within the rules. That means offense AND defense. - Gary Dillard [more]
Unread 17-02-2008, 16:09
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Going disabled changes the cylinder position
Good Morning-
This time I didn't hook the spikes up to the digital IO's in- but instead up to the relays.
When I flip the disable button on the OI the cylinders fire. They then go to that state and stay there- I can't change their positions and get the expected null movement everywhere else.
I'm terribly worried as, this year, I am actually scared of our robot. Safety FIRST!
Suggestions where to look? I initially set the spikes to 0, and only after a complicated button press do I 'latch' them open.
Jason
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 17-02-2008, 17:01
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: Going disabled changes the cylinder position
Are you using a single solenoid valve? Those switch to their default position if they don't receive the signal to go to a different one. Thus, when you hit the disable button the solenoid flips to the default position, which makes the arms move, and then you can't switch them back because the robot is in disabled mode.
Try using double solenoid valves instead, those will hold their last position if they are given no signal.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 17-02-2008, 20:00
AKA: Jason
FRC #3015
Thanks. One of my other mentors mentioned that- he has one, but I haven't been able to cost-account it yet so I haven't put it on the robot.
I'll look at switching those out. This thing terrifies me....
Unread 17-02-2008, 20:01
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
if you must use a single solenoid, have the robot default to the least dangerous position.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 17-02-2008, 22:56
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
The SMC solenoids you received in the kit are double solenoids. If you use those, you'll be set. They need to be assembled, but that is fairly simple. The air from your pneumatic system goes into the middle inlet on the side with three openings, and the two sides of the cylinder go to the outlets on the side with two holes. The pneumatics manual will explain it better than I can.
Unread 18-02-2008, 07:55
AKA: Jason
FRC #3015
Dang. We're using the FESTOs . We'll get the SMC's by the time the competition on there.
The Gyro in Disabled Mode eaglesfan10 Programming 2 09-02-2008 12:16
Paly Robotics Team 8 laser-enable the disabled pstrapp General Forum 2 22-04-2007 17:53
Robot Disabled, yet I can still actuate a Cylinder- HELP! purduephotog Programming 21 21-02-2007 16:55
LEGO ‘engineers’ compete to help the disabled Billfred FIRST In the News... 1 07-02-2005 13:45
