Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Unread 18-02-2008, 00:02
354.FIRST 354.FIRST is offline
FRC #0354
354.FIRST is an unknown quantity at this point
Questions about Hybrid Period and general rules...
1. I am assuming we get points for any ball we knock down - whether our alliance's or opponent alliance's. Correct?
2. Does a team get the 12 point bonus for having a ball on the overpass at the end of a match even if the ball was never removed from the overpass to start with?
3. Can the robocoach send only four commands in total to the robot or is it that the robocoach can send any number of commands from a selection of four possible commands programmed?
4. Would a team get points for hurdling during hybrid mode if it removed their own trackball from the overpass and then hurdled it over that same overpass (violation of rule G12) or must the team make a complete lap during hybrid mode in order to get hybrid hurdling points?
5. If a robot goes the wrong way on the track during hybrid mode, is a penalty applied? (for example if robots try to act as obstacles by heading backwards into the opponent's stretch...?)
Thanks!
Team 354
Visit our website at GWestRobotics.Com
Unread 18-02-2008, 00:15
Squirrel Lord's Avatar
Squirrel Lord Squirrel Lord is offline
Down, Down-Right, Right, Punch!
AKA: Alex Cohen
FRC #1425 (Error Code Xero)
Squirrel Lord will become famous soon enough
Send a message via AIM to Squirrel Lord
Re: Questions about Hybrid Period and general rules...
1. Incorrect, you get points depending on which balls are knocked down. Only your alliances will get you points.
2. Yes
3. Four commands may be programmed to be sent.
4. You must bring the ball all the way around first.
5. Yes.
Teams: Mechanical, OI, Drive and Animation
Competitions Attended: Portland (Semifinals), San Diego (Quarter Finals), Las Vegas (Winners with 254 and 1983), Atlanta (Undefeated in Galileo qualifying, knocked out in first round of non-qualifying matches.)
Webcomic Status: Currently Working on site and art
Expected Arrival Date: Soon
Unread 18-02-2008, 00:46
To clarify: You may have four buttons used to send commands. Each button may send one and only one command. The command set can't be changed during a match, but may be different depending on your choice of Hybrid mode, made by you.
Unread 19-02-2008, 00:58
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
A button (or whatever-it doesn't need to be a remote ) doesn't have to send a command, per se-it can send as set of "field information", which the robot can then act on. For example, a button might say "Ball on right side"-the robot would be allowed to react to that differently depending, for example, on where it was on the track.
Questions on rules and guidelines Sergio 3D Animation and Competition 10 27-01-2008 16:32
Hybrid period legal sonic remote system sparrowkc Technical Discussion 10 20-01-2008 03:43
Problems and questions about programming hedgehogger Programming 4 15-01-2005 18:18
Questions about Textures and Models thoughtful 3D Animation and Competition 28 11-02-2004 22:13
Questions about rules ahecht Rules/Strategy 9 07-01-2002 22:45
