Go to Post It's not a proper FIRST season if you don't have a robo-diet before ship date! - Mr MOE [more]
Unread 19-02-2008, 00:20
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Program Port Specs
I've been doing some research around here for a wireless programming setup, as an off-season project, and several people have mentioned that most bluetooth dongles are too slow to interface with the program port, at least when loading actual program code. I've searched around, but I can't seem to find any solid specs on the port itself. There's no reference in the PIC manuals, which kinda makes sense as the program port is an IFI implementation, but there's nothing in IFI's stuff either, aside from the basic "How to use IFI_Loader to load a program" walkthrough. Can anyone help direct me?
void function(void)
  function();
Unread 19-02-2008, 00:54
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Program Port Specs
Jake,
Kevin Watson seems to know all about the serial ports and gives the programming port a 115K baud. Look at his web site and the serial code he's written. The zip file has several readme files.
If this is an off season project. Give him a few weeks and e-mail him... he's a great not to mention generous guy and I think he has then information you may need.
Steve ( Yeah I'm a Kevin Watson Fan. )
Unread 19-02-2008, 09:59
Racer26 Racer26 is offline
I know that the company that used to make our radios (Ewave) made a product called the Stamper, which was basically the same as our old radios, only intended to be used with the program port, but these were from the pre-2004 days when our IFI boards used the Basic Stamp 2sx. I don't know if these would work with our current setup... Bear in mind, we've been told a new system is coming down the pipe for '09, so things could change again.
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Program Port Y-cable CyberWolf_22 Control System 5 01-02-2005 21:21
Program Port Y-cable CyberWolf_22 Electrical 5 01-02-2005 21:21
LCD wiring to Program port jgannon Control System 10 30-01-2005 23:28
Specs?? archiver 2000 2 23-06-2002 22:13
