Go to Post Thank you FIRST -- thank you, thank you, thank you -- I can't say that enough. We can't say that enough.... Its too bad that more of us don't try. - Aidan F. Browne [more]
Unread 22-02-2008, 17:40
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Two Questions Regarding Hurdling
So I was thinking of a strategy with a mentor, and we were thinking about blocking a ball being hurdled with a launcher. Assuming that we make no contact with the robot hurdling is this legal?
I was thinking something along the lines of having our elevator all the way up braced against an opponents overpass. When the opponent would go to launch their ball it would hit our elevator and bounce off. I'm assuming that this is a legal move because we would have made no contact with the opposing robot and if we were bumped our robot would be moved.
Now for question 2. According to the manual a Hurdle is defined as: HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS
and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
Does this mean that theoretically passing the trackball over is considered a hurdle?
I would Post in Q/A but I have no clue who has the Username and password
-Dustin Benedict
Unread 22-02-2008, 17:45
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Two Questions Regarding Hurdling
First question, legal yes. But wise? Some of those trackballs will be coming with a good velocity on them.
Second question, I don't understand what you're asking.
(since 2004)
Unread 22-02-2008, 17:56
thefro526's Avatar
Mentor for Hire.
In the second question I meant to ask is one robot passing the trackball to another robot a hurdle?
And I think If we braced our elevator right it could take the hit from a trackball
-Dustin Benedict
Unread 22-02-2008, 17:59
Originally Posted by thefro526 View Post
In the second question I meant to as is one robot passing the trackball to another robot a hurdle?
For the second question, I think it would be a hurdle.
Unread 22-02-2008, 18:01
thefro526's Avatar
Mentor for Hire.
That is what I though the rule mean too.
-Dustin Benedict
Unread 22-02-2008, 18:11
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
I think for q2, you need to be more specific. I interpret your question to be this situation:
Blueabot Alpha is has just hurdled a blue trackball over the Blue Overpass. The ball lands in the Red homestretch and is picked up by Blueabot Beta. At this point Blueabot Alpha has passed under the Blue Overpass and completed a lap. Blueabot Beta decides to pass the blue trackball to Blueabot Alpha.
At this point, Blueabot Beta passes the ball from the opponents side of the field, over the Blue Overpass, and into the arms of Blueabot Alpha.
This does NOT count as a hurdle.
To complete a proper hurdle, the robot must be in it's own homestretch.
That is, if I interpreted your question correctly.
RPI '12
Unread 22-02-2008, 18:16
That is incorrect. To have the hurdling protection, a robot must be in it's own homestretch. Still a legal hurdle.
Unread 27-02-2008, 07:39
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Also the ball has to hit the ground or a robot from the other alliance before anything else otherwise it doesn't count as a hurdle.
Unread 27-02-2008, 08:26
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
From the GDC:
Rule <G42> protects a Robot and any Trackball that may be in its possession during the Hurdling attempt. The Trackball is only protected while it is in the possession of the Robot. If a Robot launches or throws a Trackball, then that protection is no longer in effect once the Trackball breaks contact with the Robot. So, an opposing Robot may attempt to block a launched Trackball. But any team building a Robot that will attempt to do so should be very aware of the effects of momentum, inertia, impulse loads on long moment arms, dynamic stability, and what happens when an unstoppable force strikes an immovable object.
Hi!
Unread 27-02-2008, 08:57
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Question One: Probably OK, however, most of the launchers that I have seen would not have any trouble pointing a little left or right to shoot around you unless your elevator is really wide (80").
Question Two: Yes. It looks like it will be OK to pass to another robot on your alliance as long as no part of that robot is in or above the home stretch and it must be clear to the refs that for at least a split second the trackball is not in contact with the catching robot after the trackball has completely passed the finish line. There are several Q&A's that get close to answering this question but none that specifically talk about the catching robot.
MasterAlex: I searched the rules and Q&A, I am sorry if I missed it, but I did not find anything that says it must be a robot from the other alliance. This could impact several strategies we are working on. Could you please point me in the right direction to find that ruling, I could have missed something. Thank you in advance.
Unread 27-02-2008, 10:16
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Unless you can reach over 11' high, our robot (Phoenix) will have no problem shooting over you
I would think most (if not all) can do this.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 27-02-2008, 12:28
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
Another thing to consider if this strategy is employed is the moment arm that is created by bracing against the overpass. I believe that if you are blocking and not attempting to hurdle a bump from another robot is allowed to signal a pass. Even a small bump to signal a pass may have devastating consequences.
Dan Cell
Systems Eng. Mentor
Team 836 - The Robobee's
Few Questions regarding IR board itsme Electrical 3 14-01-2008 14:55
Questions regarding lane divider CVHSARG Rules/Strategy 2 07-01-2008 22:11
Questions Regarding Rules compasswilting Rules/Strategy 6 13-01-2007 14:56
Questions regarding Vex Competition team399 FIRST Tech Challenge 4 15-12-2005 15:41
Questions regarding textures in 3D Studio Max Ryan Dognaux 3D Animation and Competition 6 16-02-2003 14:26
