pic: Team 166's Desperate Weight Saving Measures - 1
Re: pic: Team 166's Desperate Weight Saving Measures - 1
you could also lose a tiny bit from trimming off the 3/8" of bolt sticking out past the nut. about an hour with a dremel and you could save a couple of ounces from each wheel.
might mess up the threads but times are desperate |
These are the wheels on our practice robot and we don't really have to take the time cutting down those bolts. We just did this to the practice robot to make sure the wheels would still work properly. We probably already cut down those bolts on our competition robot. I can't remember. |
what kind of bolts are those? I believe switching to aluminum bolts would save some weight.
It looks like the bolts are stainless steel. I personally wouldn't use anything but stainless steel or steel on anything in the drive train just because of the beating their likely to take a beating. We had some aluminum bolts sitting around our shop a while back and I wouldn't even use them on a vex robot.
| pic: 166's '08 Robot: Atlas | Dan Petrovic | Robot Showcase | 4 | 24-02-2008 14:59 |
| pic: Team 166's Gemini as of 2/12 | Dan Petrovic | Robot Showcase | 2 | 14-02-2007 00:32 |
| Team 166's robot | Eric Finn | Robot Showcase | 20 | 28-01-2007 23:06 |
| pic: 166's build season schedule | Dan Petrovic | Extra Discussion | 12 | 13-01-2007 00:19 |
| pic: Saving weight (and rotational mass) | M4 Sherman | Extra Discussion | 11 | 09-08-2006 00:20 |
