Go to Post Taking some parts from an old robot isn't cheap, it's like adding a piece with more experience to the new robot. - Marcel [more]
Unread 24-02-2008, 11:24
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
How to TRansferring easyc to mplab
During our 10 hr window today i transferred my easyC program into mplab. It was long and tedious, and I'm still working on taking care of " Set PWM". Other than that, everything else has just involved converting everything through notepad to a .c or .h file and then cutting and pasting in the appropiate file of the default code. ( I replaced default_routine with operator control.) I did this because I am tired of dragging blocks, and I think I can handle MPlab. Out of curiosity, does anyone know an easier way to do this? Also, I am willing to walk anyone through this process if you would like, just pm me
Unread 24-02-2008, 12:59
David Bliss David Bliss is offline
FRC #0904
David Bliss is an unknown quantity at this point
Send a message via AIM to David Bliss
Re: How to TRansferring easyc to mplab
You probably want to look into WPILib. Some of the samples should look somewhat familiar. If you don't use WPILib, you eventually try to mix oil and water. That becomes particularly obvious with the various sensors; unless I'm mistaken, all the functions easyC uses to work with sensors just plain don't exist in the default code, nor in Kevin's code.
There are plenty of threads out there on using WPILib. I haven't looked for one that covers using WPILib with MPLab, because I personally prefer to go with Eclipse. If there's no thread already, you should get an answer soon enough from someone if you post in WPILib's subforum.
Good luck.
Unread 24-02-2008, 13:21
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
My issue is not that the transferred code does not work. I edited the default code header and source code files so heavily it could hardly be considered anything but an amalmagation of code. I was simply wondering if there was an easier way to convert it all. In truth the work it took to edit it all together was probably more than if I had just written it all in mplab to begin with. Thanks though.
Unread 24-02-2008, 13:25
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
AFAIK easyC generates WPLib-compliant code... so if you used its libraries, you could essentially just drop your code into mplab and it would work stock.
What David said about sensors being oil-and-water is definitely true, as WPLib/easyC uses the user processor to handle sensor routines, which is totally different than Kevin's code.
Unread 24-02-2008, 14:47
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I'm sorry, forgotten to mention that I imported the API.h file into MPlab. Yes, I was using WPlib with easyC before I transferred the code.
As far as I have seen, the code works. I am seriously thinking about rewriting the whole thing from scratch in MPlab though, just to make sure.
As for the sensors, I was not aware of that, thanks. Last I checked they were working, however for the sake of caution I may write it myself during our next fix it window. The last thing I would want is for me to have to rewrite it during the practice rounds at competition. I am the only programmer, a freshman who just started learning it at the beginning of build. Again thanks for telling me about the sensors, I'll look into that.
Unread 24-02-2008, 14:53
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I'm really confused. Are you trying to say that WPIlib/easyC run the sensors from the master processor? If so that is not true.
Kevin's (or anybody else's sensor drivers) or WPIlib/easyC's drivers for that matter all run in the same place. All WPIlib/easyC does is hide what is actually happening from you, just as C hides you from what it actually takes to multiply an integer by an integer.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 24-02-2008, 15:17
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I had thought that too, Q but ill look into it somewhere in "all" my sparetime.
Unread 24-02-2008, 18:40
Tim Arnold's Avatar
-q
I stand corrected, I thought that the sensor processing was done on the user processor for some reason. Thanks!
Unread 24-02-2008, 18:42
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
So the way that I am doing the transfer is, if not the best way, a valid one?
Transferring code over to mplab from easyC SL8 Programming 4 25-02-2008 08:46
How to get EasyC code into MPLab rhoads2234 Programming 6 08-06-2007 14:45
Transferring EasyC for Competition Day Kingofl337 Programming 0 06-03-2006 11:38
Transferring EasyC for Competition Day Kingofl337 Programming 0 06-03-2006 11:32
