Go to Post Understand that not only can you learn from other experienced engineers, but also mechanics, farmers, and craftsmen. - Andy Baker [more]
Unread 25-02-2008, 19:28
drosophyllum drosophyllum is offline
FRC #0545
drosophyllum has a spectacular aura aboutdrosophyllum has a spectacular aura aboutdrosophyllum has a spectacular aura about
circuit breaker malfunction
Has anyone had the Hi-Amp BussŪ 120A curcuit breaker open the curcuit temporarily without triggering the reset lever?
Unread 25-02-2008, 19:45
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: circuit breaker malfunction
Just posted on your other thread... As for the 120A circuit breaker, we've never had any trouble with it. You may have a defective one, but I doubt it. You may be pulling too many AMP's through your main breaker (Do you have a lot of motors on your robot? Are they geared to go really fast?) or you may simply have a short. Make sure none of the cables after the breaker have rubbed away their insulation and are touching.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 25-02-2008, 19:55
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Yes I have had the 120 Amp breaker fail on me before. The robot would lose power while sitting on the field. The switch still felt fine when you switched it on and off. It's hard to find that problem sometimes. We just replaced it with a spare.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 25-02-2008, 20:59
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I would check closely for loose wires. Give all of your main distribution wiring connections a little tug and see if anything pops loose. Your description sounds like intermittent connection problems to me. You could also have a connection that is crimped over insulation. You can check for continuity with a circuit tester, too. Of course these tests should be done with the battery removed from the robot.
Unread 25-02-2008, 23:39
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
yep check all of your loose wires and make sure it clicks when you turn it on.
Last year ours actually broke and we had to order a new one
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 26-02-2008, 08:11
Yes, on a rare occassion these do fail. It is a problem during manufacture. We test all of the breakers with this simple test. Turn on the robot, then lightly tap the red reset button. If the robot power is intermittant, replace the breaker. These devices are bimetal, temperature reacting, "snap action" devices. During manufacture, the bimetal contact is riveted in place and a light misalignment of the rivet press causes the bimetal to deform enough that it doesn't press against the opposing contact when turned on. This condition gets worse with time as the light contact causes localized heating and arcing of the contact surfaces.
circuit breaker board oljomo Inventor 4 08-03-2005 10:57
Cheap circuit breaker krhs_programmer Electrical 11 23-02-2005 00:04
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
120A Circuit Breaker BrianB Kit & Additional Hardware 4 06-01-2003 14:02
circuit breaker archiver 2001 2 23-06-2002 23:18
