auton. mode
In auton mode, if your robot crosses your finish line (4 points) and then lets say hits a wall and then somehow ends up going back the way it came, thus crossing over the finish line it just crossed. What is the outcome here? 0 points? or 4 points - 10 point penalty = -6 points?
A similar question may have been asked before but i couldnt find it. |
Re: auton. mode
You'll get your 4 points for crossing the line, and then get a penalty of -10 for crossing backward. If those would happen to be the only points of the entire match, you will end up with a score of zero - there are no negative points. But most likely you or an alliance partner will score more points. The penalties are taken off at the end of the match.
Re: auton. mode
basically, the penalties are counted separately from what you score, so if you cross one line (+4), and go backwards (-10), the score should show 4 points, go into teleoperated mode, and then at the end of the round it will say "penalties - 10" or soemthing, and subtract it then. Your score only increases on the scoreboard until the end of the round where penalties are subtracted.
| Auton mode next year¿ | Rickertsen2 | General Forum | 32 | 30-03-2003 23:01 |
| auton mode running motors incorrectly | BK36 | Programming | 2 | 12-03-2003 02:43 |
| Can't figure out auton mode | TangoBravo1318 | Programming | 1 | 20-02-2003 10:06 |
| Help! Auton mode! | TangoBravo1318 | Programming | 2 | 20-02-2003 09:34 |
| Auton Mode simple question | Morgoth | Programming | 7 | 10-02-2003 10:10 |
