KoP Revamp?
I heard something about ifi updating all of their electronics for the robots next year.
any more information on that, or is it just a rumor? i'd assume innovationFirst is gonna have a bit more cash flowing now with them owning vex and all. so what are we in for? ![]() |
Re: KoP Revamp?
we're in for no IFI next year
Re: KoP Revamp?
Yep, no IFI but they have said that the programing will continue to be C or C++.
Re: KoP Revamp?
O Rly?
so whats it going to be instead? or have they not announced it? or is FIRST trying to pull it off themselves...? |
Re: KoP Revamp?
There's been info floating around about multiple sources making the control system. I don't believe much of it except that fact that team will still be able to use C and most likely the OI will not use gameports.
Some sources are reporting that it will be similar to the new FTC platform's control system. If so it looks like we're in for some cool surprises. Remember though that we will be using new speed controllers, relays and anything else dependent on IFI next year. (unless first gives us the option to reuse these parts) |
Re: KoP Revamp?
THANK YOU GOD!!!!!!!!!!!!
hahaha what would they use instead though? hope to god they don't shoot for usb. that would suck for custom circuits. eitherway i'm excited to see some new stuff roll out! |
#7
Re: KoP Revamp?
![]() Or better get one of the ~$99 daq modules and make whatever controller you want. |
#8
Re: KoP Revamp?
i wouldn't trust any circuit with it. |
#9
Re: KoP Revamp?
What about an FTDI Chip. They're normally used to go from RS232 to USB, but I don't see why you couldn't do it in reverse.
They're relatively cheap, and fast enough for input. |
#10
Re: KoP Revamp?
The USB DAQs can be quite fast though ... depending on the overhead of the DAQ driver. Something like This or this could be a real possibility. |
#11
Re: KoP Revamp?
Re: KoP Revamp?
and its hard enough going through that mess with operating systems, |
#13
Re: KoP Revamp?
I understand that USB things need drivers, I was just saying If you wanted to do it there is a way. Next year will be a learning year for almost every team and you will see a lot of people sharing their experiences on how to interface with the robot, so I wouldn't worry about too much of anything yet. Also I highly doubt FIRST will give us this new control system without some technical documents to help us out. In the past almost anything you could ever want to know about the current control system has been published and in time it will be the same in time, just you watch.
#14
Re: KoP Revamp?
As far as drivers go, here's my thought.
Childboarding is your friend. |
#15
Re: KoP Revamp?
I remember FIRST sending out a huge survey last year about the KoP. Maybe they will change some stuff around with the new control system.
| KOP Sprockets | Bsteckler | Kit & Additional Hardware | 0 | 02-02-2008 10:38 |
| KOP photos? | Gary Dillard | Rumor Mill | 13 | 04-01-2006 20:56 |
| KOP Gyro | John Gutmann | Programming | 12 | 12-12-2005 21:59 |
