plasma cutter/liquid nitrogen
Is it possible to combine the two? Would it cause an explosion. Plasma is technically just super-heated particles, so could you super heat liquid nitrogen to turn it into plasma? Would it still have it's freezing effect? Just curious about this. Seeing as nobody will give me liquid nitrogen or a plasma cutter to play with, I was wondering if anyone knew any of these answers.
Re: plasma cutter/liquid nitrogen
I don't know the specifics of making something plasma but my guess would be no considering Nitrogen is an inert gas. |
At the temperatures involved with plasma cutting of 10,000 degrees C or greater, the liquid nitrogen would become gaseous nitrogen very quickly.
From http://www.mwsco.com/kb/kb_frameset.asp?ArticleID=64 which is a pretty good explanantion of the plasma cutting process: "The different gases used for plasma arc cutting include nitrogen, argon, air, oxygen, and mixtures of nitrogen/hydrogen and argon/hydrogen." So yes, you can use straight gaseous nitrogen for plasma cutting, although most of the "garden variety" units I have used over the years have used plain compressed air (which is still mostly nitrogen). The other gasses tend to be used for specialized applications. |
| gas nitrogen springs | comwiz7 | Pneumatics | 3 | 12-01-2008 21:42 |
| Making a plasma cutter go. | Madison | Technical Discussion | 1 | 08-11-2006 16:34 |
| Plasma Cutter | M. Enns | Technical Discussion | 7 | 17-12-2005 21:49 |
| pic: Sheet steel resting on CNC plasma cutter | Jay H 237 | Extra Discussion | 3 | 11-01-2005 05:46 |
| Liquid Nitrogen Ice Cream | Ian W. | Chit-Chat | 12 | 11-08-2002 19:05 |
