Wireless Router Issues
At Philadelphia we had our scouting system up and running for everyone to use. We constantly ran into issues with our router crashing however. We used a Linksys WRT54G with dd-wrt firmware. Stock settings are to hand out 50 dhcp addresses, which we hit midday Thursday I think. I upped it to 250 maximum users, but we started running into issues with the Wi-Fi just dropping out of existence (no one's device could find it). We had a few things hardwired into the router, and they continued to function normally. We had about 70-80 DHCP entries around this time.
Is the issue with the router handling too many DHCP users? Would running the DHCP server on a computer behind the router, thus making the router function only as a access point/switch? Or can a WRT54G absolutely not handle this traffic load? Is there any wi-fi system that is more powerful? |
Re: Wireless Router Issues
hmm.. dd-wrt, means you are using a v5 router which has only 8mb ram and 2mb flash?
You'd be better off with an older one which has more flash .. But if you are thinking of serving a whole arena of users (probably > 250) I think you will be better off with a linux box giving out serving DHCP on class A or B subnets, with the router merely bridging your wireless and wired interfaces (i.e. disable internal dhcp). The number of requests / flows may also be maxing out its ram. |
You might see a somewhat greater number of simultaneous users if you run in G only mode. If you want to increase the number of connected clients, you could run 3 access points on the non-overlapping channels 1, 6, and 11, and route them on the WAN side of the 3 WRT54G's. |
I have a v2 WRT54G, so it is with 16mb of RAM. I just upgraded to dd-wrt v24 RC 6.2, and I'm going to try and disable as many functions as possible. It's impossible to test until we get to an event though ![]() |
While I was reading the Championship Essential Information I noticed that it asks people not to set up wireless networks at the Championship.
I <3 the DD-WRT firmware. It does wonderful things traditional router firmware cannot. I've used it on a WRT54G v7 and it would use up about 94% of the memory just idling. So, perhaps you are hitting the upper limits of your memory?
#7
Tomato firmware rocks too
#8
You can try wiring a second router behind the first router to ease the load instead of having a computer.
#9
I'm going to try using a gigabit switch with two wireless access points connected, and either a computer or a wired router giving out DHCP addresses. This way, all wireless connections are split between the access points, and all traffic goes through the switch - which should be more than capable of the load. |
#10
Although I believe this 'rule' covers the entire event (Stands + Pits), I don't see where you would get power to run one in the stands anyways, as I am pretty sure there is no AC easily accessible.
That being said, I don't think they would mind an ad hoc wireless network being run in the stands, which ought to work for a scouting system. |
#13
Yeah that should work in the stands for match scouting, but for team scouting we rely on a server in our pit with clients connecting + entering info.
#14
I'm not sure why they are showing negative love for the WiFi, but please respect their decision. |
#15
This could be because maybe FIRST is doing a frequency study for the new control system.
If FIRST decides to go with 2.4 Ghz for the new control system, it could spell the end for all team owned WI-FI networks at events. |
| Bypassing router | Mark Rozitis | IT / Communications | 17 | 13-12-2007 18:06 |
| Wireless Gamepads | lazyxninja | Control System | 1 | 27-01-2007 15:35 |
| Help with VPN router | Scott L. | Technical Discussion | 4 | 10-07-2006 13:33 |
| 2 Wireless routers | MattK | Chit-Chat | 7 | 02-06-2004 20:46 |
| Linksys Router Help | mtaman02 | Chit-Chat | 10 | 18-03-2004 01:04 |
