Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
View Poll Results: You Make The Call
Redalliance wins 118-110. We're going to a rubber match! 9 25.71%
Blualliance wins 122-118 and takes home gold at the Dogwood Regional! 26 74.29%
Voters: 35. You may not vote on this poll
Unread 07-04-2008, 15:25
Ashburn Ashburn is offline
FRC #0600
Ashburn is just really niceAshburn is just really niceAshburn is just really niceAshburn is just really niceAshburn is just really nice
YMTC: Bluabot comes to rest touching a blue trackball on the overpass
Thank you 2008 GDC! You Make The Call (YMTC) is a series of situations where you are the official and make the call.
Please reference specific rules when applicable. The results of YMTC are not official and are for educational purposes only.
Welcome to the inaugural Dogwood Regional! We are here in the second match of what has already been a thrilling final. Bluateam, with their #1 seeded, yet-undefeated, fast-driving, high-hurdling Bluabot, has, in cooperation with strong alliance partners, come to the very precipice of victory at Dogwood. In the first match of the final round, however, Redalliance gave Blualliance a run for their money in a match that ended with a Blue victory, 108 to 106. As the second match of the finals gets underway, the scoring is fast and furious. Both teams are going for broke and the hurdles just keep on coming. With only 15 seconds to go in the match, Redalliance has a 10 point lead over the mighty Blualliance, 118 to 108. With 11 seconds to go in the match, Bluabot caps a blue trackball on the Blue Overpass and crosses the Blue finish line. Seeing that Blualliance may still need to put more points on the board in order to eek out the win, Bluabot races around the track to try to get one last lap in before the buzzer.
Bluabot weaves in and out of traffic as it flies around the track. Bluabot turns on the jets as it crosses the opponent’s finish line with just seconds to go. Rounding the last corner with only one second remaining, Bluabot heads for the Blue finish line. When the clock strikes zero and the buzzer sounds, Bluabot is still 5 feet from the finish line. Bluabot coasts to a stop underneath the overpass. In the stands, Blualliance’s fans look at the real-time scoring ( 118 to 110 in favor of Red) and factor in the capped blue trackball and erupt into cheers of victory! But wait! The referees are inspecting the blue trackball on the overpass. It appears that Bluabot has come to rest in a position where its ball-removal device is touching the blue trackball on the overpass!
Assuming a penalty-free match, does Bluateam's alliance get the harrowing 4 point win and take home gold at the inaugural Dogwood Regional? Or has Redalliance held on to score an upset victory by 8 points to force the finals to a rubber match?
Based on the 2008 Rules, YOU MAKE THE CALL!
Last edited by Ashburn : 07-04-2008 at 15:52. Reason: (space-time continuum collision avoidance)
Unread 07-04-2008, 15:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: YMTC: Bluabot comes to rest touching a blue trackball on the overpass
This is easy if you've read the latest Q & A:
At the end of the match, when the timer reaches 0, the trackball was not in free-flight. The robot's exact position when the clock reaches 0 is all that matters. Therefore, when the clock hit 0 the robot was not in contact with the ball and therefore meets the requirements of a valid end-game bonus.
http://forums.usfirst.org/showthread.php?t=9296
If the Trackball is not in free-flight (i.e. in contact with a Robot or the Overpass or other field element) when the clock reaches zero, then the Trackball’s contribution to the score will be based on the conditions that exist as the Match ends.
GitHub
Unread 07-04-2008, 20:46
dilbert's Avatar
dilbert dilbert is offline
AKA: Adam Lindsley
FRC #0386 (Team Voltage)
dilbert will become famous soon enough
Send a message via AIM to dilbert
Yep, that is absolutely correct. The Definition of the end of the match is at the end of Teleoperated Period, when the timer shows zero <G02>. A trackball "capped" is considered capped when the match ends, or when the timer reaches zero <G14>. The Trackball bonus is awarded.
I think I accidentally voted wrong. I got the color of the ball confused...BlueAlliance Wins!
Unread 07-04-2008, 15:42
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Based on <G14>, there is a problem in that the ball is in contact with a robot of the same alliance, and would not score.
BUT, the robot was not in contact at the end of the match. This is defined in rule <G02> as when the clock reaches zero seconds. All stationary trackballs are scored at match end, trackballs in motion (and unrestrained) are scored when they come to rest.
Therefore, the trackball counts, Blues gets the 12 point bonus.
Former Mentor Team 1771
Former mentor Team 4509
Unread 07-04-2008, 15:45
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Another trick question! You aren't going to fool us this time! The situation as described can't exist. In the first paragraph of the problem, "Redalliance has a 10 point lead over the mighty Blualliance, 118 to 108". But in the second paragraph, the scores suddenly flip and Bluealliance is winning 118-110 ("...real-time scoring [118 to 110 in favor of Blue]") with no explanation for what has happened. Since this obviously can only happen when a rift in the space-time continuum collides with an improbability singularity, we have to officially put this in the "I don't think so" file.
Okay, assuming the above condition was the result of a simple typo and the intended situation is one where Redalliance is winning prior to the addition of bonus points at the end of the match, then the outcome is straightforward:
Robots are scored based on where they are when the buzzer sounds. Trackballs are scored based on where they are when the buzzer sounds, or where they come to rest if they are in unrestrained motion when the buzzer sounds.
At the sound of the buzzer, Blueabot was five feet from the Overpass. It is scored based on that position. At the sound of the buzzer, the blue Trackball was at rest on the Overpass. It is scored based on where it was at that moment. Anything that happens after that - including Blueabot coasting into contact with the Trackball - is irrelevant and does not matter.
The referess quickly realize that there is no issue here and declare the winner. Bluealliance justifiably erupts into joy.
-dave
Unread 07-04-2008, 19:44
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
FRC #1511 (Rolling Thunder)
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
This one's easy and was covered at the Philly Regionals. The Robot is scored where it was when the buzzer sounded. Had the ball been in motion it would have been scored where it came to rest. The "hang" counts, but crossing the finish line does not because the robot was scored at the point it was at when the buzzer sounded - prior to crossing the line. Blue Alliance (clap clap clapclapclap)
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
Unread 07-04-2008, 19:48
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
that happened in bosten to 1699 yes it made us mad but hey it happens.
Curie..
Unread 07-04-2008, 20:04
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I agree that blue alliance should win.
Just a note to all: Make a robot that stops when the clock does and you won't have to worry about it.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
[YMTC]: YMTC: Bluabot hurdles from outside the Home Stretch? Ashburn You Make The Call 9 07-04-2008 11:32
removing trackball from overpass Tyler Grooms Rules/Strategy 4 15-01-2008 12:39
pic: Dimensions of the Trackball on the Overpass Bethany Mc. Extra Discussion 2 07-01-2008 09:01
YMTC: Bluabot Caps Redabot Natchez Rules/Strategy 4 15-01-2007 09:47
YMTC: Bluabot sits on Redabot Natchez You Make The Call 19 08-04-2004 16:43
