So in a strategy meeting last night, one of our mentors suggested that at the beginning of the match, the balls are not truly random; as the sequence of balls is always blue-red-blank, and would therefore lead to a situation where no two balls of the same color are on the outside of the field.
i dont see how his logic is working, nor i cannot see how its right/wrong. Any help? |
Re: 3-3
That statement is not true, and here is an example to reject it
http://www.hhsrobotics.org/Videos/Vegas_Q1M1_SD.wmv |
Re: 3-3
That would be because of rule <G20> :
Re: 3-3
Thanks (=
Re: 3-3
this is the old version of <G20> that you are reffering to. It would be useful if you get the new one.
however, there is no diffrence regarding this thread's question. |
Re: 3-3
Well, although the randomizer truly randomly sets the trackballs, here is food for thought!
Whats the chance that in a match prior to yours, the balls will be in exactly the same place? Well, FYI, I kept track of just about every match when we were queued and watched where the balls were prior to our match. Only twice in three regionals did the ball end up in the same place. I'm talking about just our ball. The reason we were tracking them was due to the fact that our ball knocker during hybrid could hit it if the ball was in front of us. We always tried then to put the robot in position where the ball wasn't in the previous match. So rather than having a 1/3 chance, we were hoping for > 1/3 chance to have it in front of us. I know you cant count on it, but what the heck, it was worth a shot, and it didnt hinder our alliance from doing what they wanted in hybrid. Now we only tried it if our alliance partners couldnt knock the ball off and/or didnt move in hybrid. |
#7
Re: 3-3
Re: 3-3
There are 6 possible arrangements:
RB- BR- R-B B-R -RB -BR So the chance that the one that comes up is the same as the previous one is 1/6. |
#9
Re: 3-3
Yes, 1/3 if your just tracking where your ball will be if you place your robot in front of one of the possible locations of the overpass.
#10
Re: 3-3
What i suggest you do is watch videos from several regionals and find the algorithm that generates the ball postions (if the out come is known then the forumla can be generated). This is like major cheating, and very not GP.
#11
Re: 3-3
If the "Randomizer" is random, then no formulas can be found. If it not actually random and somebody figures out the formula, then It is their superior scouting and pattern-finding talent, and they are welcome to use it. it is completely fair since every team could watch the matches and potentially find the pattern. Last edited by BornaE : 12-04-2008 at 22:24. Reason: spell check |
#12
Re: 3-3
computer can not generate random, computer have not or will never understand random, random is something that can only be generated by a intelliegnce and then it can still be predicted to a degree.
Random in a computer is a complex algorithm faking random, its really really really really complex so the answers seem random but the more data you have the closer you can build a similar algorithm, see a math genius its possible. Quote:
#13
Re: 3-3
Re: 3-3
EDIT: The method mentioned by Uberbots above is also used and would also render any amount of match watching useless. |
#15
Re: 3-3
the computer can read the time that the operator tells to start the randomizers animation and use that random variable to generate where the balls will end up. This method would be truly random. plus, if you get on TBA for the next 4 days,(which some of our people will actully do ) they will have quiete the best scouting DB. |
