Go to Post Everything is possible. Some things are just harder to do than others. - vigkvagkv2 [more]
Unread 14-04-2008, 06:28
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
[TBA]: TBA FLV Downloader
(Sorry for the double post, but I realized that most people aren't going to see new messages in the TBA forum)
Since working on Dashboard for FRC, I've needed to learn some C#. In my quest to learn more programming languages, I've created an FLV Downloader for the TBA API.
http://bobcatrobotics.org/tba_api/Setup.exe
It allows you to get the FLV files that you usually stream off of thebluealliance.net. You have the option of (in any combination) to get all the videos of a specific team, specific event, or competition level. Once you hit 'Get List', you'll be presented with a list of all the matches it found. Sorry for the arcane-type listing, but when there is a lot to list, everything bogs down. It should be fairly easy to figure out though. Some of the common short codes are:
qm = qualifying match
qf = quarter final
sf = semi final
f = finals
m = match number
eg: pa_sf2m1.flv = Philadelphia Regional, Semi-Finals 2, Match 1
I hope this application will help at Nationals if you want to review videos of matches in other divisions for scouting, etc. Keep in mind this is my first C# application so there might be a few bugs. Please reply here with any bug reports, comments, suggestions, etc.
Thanks,
Dave
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
[TBA]: TBA FLV Downloader Ctrl Alt Delete The Blue Alliance 2 14-04-2008 15:29
[TBA]: Issues with TBA API FRANK(WGH) The Blue Alliance 7 17-03-2008 11:39
[TBA] Sumbit your Robot Photos on TBA lynca Robot Showcase 0 11-03-2008 13:25
[TBA]: Schedules and TBA API proegssilb The Blue Alliance 3 09-03-2008 15:55
[TBA] TBA Presents... Soldering and Multimeter Tutorials Greg Marra General Forum 0 27-01-2007 20:15
