Go to Post Sometimes, it takes years to gain respect and to learn to understand the opportunities that avail themselves to those who pay attention, are willing to learn from the best, and dig deeper into understanding what it means to be a competitive FRC team. - JaneYoung [more]
Unread 15-04-2008, 10:52
qpang qpang is offline
qpang is an unknown quantity at this point
Drive wheel motors using OItoPWM() --- how to debug?
I'm using OI_to_PWM() function to drive wheel motors during the Operator part of the game, and set_PWM() during the Autonomous part, setting to full speed.
It is observed that during the operator mode, it is running slower than the Auto mode, even the driver pushed the joystick to the limit.
I assume when the joystick is pushed to the limit, the output to PWM port should be 255(or 0) using OI_to_PWM() function. Is that true?
Is there a way to read the output to the PWM while running the OI_to_PWM() function using EasyCPro? I mean without any hardware equipment?
Unread 15-04-2008, 10:58
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Drive wheel motors using OItoPWM() --- how to debug?
Use the OI Analog Input block, and throw that to a variable (int should be fine.) Then you can print out that variable, and see what it is.
Jacob
Unread 15-04-2008, 11:29
Not necessarily. Most joysticks don't quite reach the entire range of possible values. You can compensate for this in teleoperated mode by calibrating the Victor speed controller to match what your joystick provides.
(Note that the maximum PWM value in the IFI control system is 254, not 255.)
If you already have a laptop computer with a serial connection, you can use a dashboard reader program to see exactly what pwm outputs are being commanded, and exactly what joystick values are being read.
How to get robot to drive straigth using shaft encoders eccmaster Programming 5 02-02-2008 23:50
Four Wheel Drive Using Standard Transmissions daviamp Technical Discussion 4 18-01-2006 20:03
Using 6 motors in a drive system? FIRST JerseyKid Motors 7 12-01-2005 23:49
How many motors are you using to drive? Joseph F Motors 18 16-10-2002 21:24
