Go to Post Due to risk of unforseeable consequences, teams may not initiate a wormhole for the purpose of scoring ringers from past or future matches. - Richard Wallace [more]
Unread 19-04-2008, 21:09
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
3 speed transmissions
Does anyone know where to buy a 3 speed transmission or specific instructions on how to build one
R.C.
MadTown Robotics Team 1323
Unread 19-04-2008, 21:12
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: 3 speed transmissions
I believe dewalt trannies are 3 speed. I am not positive on this though.
Andymark does not sell 3 speed ones.
If you don't mind me asking, why do you need 3 speeds? Most teams find 2 sufficient.
thanks, Vivek
"we don't build robots, we build people"
Unread 19-04-2008, 21:16
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Dewalt transmissions are the main 3 speed transmissions commercially available practical for FIRST. They can be purchased directly from Dewalt, and then must be modified, according to the instructions in Dr. Joe's Whitepaper "Nothing but Dewalts" to accept a CIM motor.
CraigHickman
Posts: n/a
Also, if you're going to custom fabricate a tranny, it's much simpler and lighter to do 4 speeds rather than 3... Unless you go servo, which is not the most reliable (in my experience) for a 3 speed.
Unread 19-04-2008, 23:58
R.C.'s Avatar
How do you make a four speed?
R.C.
Unread 20-04-2008, 00:15
Valley Raider Valley Raider is offline
FRC #0955
Valley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really nice
Do you use CAD models?
I don't have any of my models with me but I could post one them so you can take a look. I have a 2 and a 4 speed, we build the two speed one. Its going to be hard to just describe it how to make one if you've never seen one up close. I'll put something together and put up a post. I've been meaning to have the design critiqued by the CD crew.
I would recommend searching for post on this topic, there are thousands.
Unread 20-04-2008, 01:48
Build a two-speed, then add another shifter section. (OK, not quite that easy, but that's the basic idea.)
Unread 20-04-2008, 10:07
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
You would have your first two reductions coming in off of your main input or lay shaft going to your primary shifter shaft and then a 1:1 reduction and another reduction off of your primary shifter shaft to a secondary one.
This gear selection would give you four speeds.
Shaft 1 gear a + Shaft two 1:1 = Reduction a(1)
Shaft 1 gear b + Shaft two 1:1 = Reduction b(2)
Shaft 1 gear a + Shaft two Gear c = Reduction a * Reduction c = Reduction x(3)
Shaft 1 gear b + Shaft two Gear c = Reduction b * Reduction c = Reduction y(4)
I have these pictures for a bit of a visualization. this is something I designed a while back with the use of the gearset of an AM Gen 2 for the first stage, the shaft would be custom. It could also be done without the 1:1 but I chose to keep the original Gen2 reduction and only use a third gear to go further.
Unread 20-04-2008, 10:27
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Im pretty new to the concept of two or three speed transmissions (our team just stuck to the KOP toughboxes)
What exact do those pneumatic pistons do?
this is kinda stretch, but does anyone have a two or three speed transmission in action on video or something
thanks
Unread 20-04-2008, 11:24
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I would really recommend either using an andymark 2 speed or using the dewalt if you do not have a machine shop willing to do the work for you. The precision required to make a transmission is very very important.
Mentor 2415
Unread 20-04-2008, 12:51
thanks
The pistons shift gears. Servos can also be used, if you are careful.
I'm sure there are some, but you'd get the whole robot. (330 2007-2008, for example. No gearbox-only shots, but there are times you can tell they shift gears.)
Unread 20-04-2008, 13:19
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
The pneumatic piston is used to shift the dog between gear sets. The gears that the dog engages are on bearings so they can spin independent of the driven shaft. The pneumatic pushes the dog against the gears locking them against the gear to power it. The dog is basically a rotating disc that engages into the gear via pins or other couplers. In the pictures posted above there is an internal shaft that the pneumatic pushes that is pinned to the dog.
Also if you are looking to make your own three speed transmission I would suggest looking up team 222 Tigertrons. They have a really sweet three speed transmission that they've used in the past (I haven't seen them this year so I'm not sure if they used it again or not).
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 21-04-2008, 09:15
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
We haven't used the three speed since 2004, but we have used our TigerDrive 2 speed version since 2006. The TigerDrive is still a ball lock transmission but it is much more compact and light than in 2004. The main reason we switched to a two speed is because we really hadn't seen the need for three speeds in recent games. One nice thing about the ball lock is you can keep stacking gears together until you run out. We had talked about making another three speed based off of our current TigerDrive that would weigh no more than 4 lbs, but this year's game really didn't need it. I guess the best advice I could give is the best spent time is going to be determining whether or not the game and your team strategy requires 3 speeds.
More information on our three speed can be found here: http://www.chiefdelphi.com/media/papers/1539
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 20-04-2008, 11:39
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Here is the instructions on making a 3 speed robot legal transmission from the DeWalt transmissions and mounting it to the CIM motors and the robot.
The BoM and where to buy are in that white paper although I'd suggest experimenting with different ways of shifting other than the servos.
___________________
- Tennyson, Ulysses
Dewalt 3 speed transmissions for sale Happyman Motors 45 19-02-2009 17:24
2 Speed Transmissions in the Future Jherbie53 General Forum 29 09-05-2007 18:18
Are two speed transmissions worth it? thefro526 Technical Discussion 43 19-04-2007 21:16
AndyMark 2-speed transmissions gabrielse Kit & Additional Hardware 3 08-01-2007 11:32
New Ryobi 3-speed drill transmissions! artdutra04 Technical Discussion 5 23-04-2006 19:48
