Joystick and keyboard output question (PC)
I am trying to write a code for converting joystick outputs to keyboard controls, but I can't seam to find where I can call the outputs from. If someone can show me where to find these variables. I also need to know the same things for keyboard outputs (in specific the arrow keys).
Thanks, Alex Dinsmoor FRC 201 |
Re: Joystick and keyboard output question (PC)
I.. think this is what you are asking.
http://www.ifirobotics.com/docs/lega...e-2004-1-7.pdf Look at the different tables they have on the ports. The variables are named like "p1_sw_trig" (see the Variable Name column) This doesn't cover keyboard input or anything. Could you elaborate more on what you are looking for? |
If you are looking for keyboard output (keyboard meaning a computer keyboard, not a robot one?), I think what you're looking for are scan codes (wiki article), which is what the keyboard sends as a number when a key is pressed. Are you trying to use a keyboard to control a robot instead of a joystick?
Here is a very simple routine I did once to test C (not C++) keyboard output: Code:
void stream (void) //type out info
int ch;
while ( (ch=getch()) != '\r') //loop until ENTER key pressed
if (ch==0xE0) //signals 2 char arrow code
RShow(ch);
//printf("%c=[%d] or [%X] ", ch, ch, ch);
ch=getch(); //get second character
RShow(ch);
//printf("%c=[%d] or [%X]\n", ch, ch, ch);
else if (ch==0x00) //signals 2 char function key
else //regular old ASCII code (single character)
//putch(ch); //display char
void RShow ( char ch )
printf("%c", ch);
printf("=[%-3d]",ch);
printf(" or [0x%-2X]",ch);
printf("\n");
Come to think of it, these might not be true "scan codes", but are actually semi-processed numbers. True scan codes I think send the actual keyboard key and you have to figure out what key that represents (depending on hardware), and then mix in the shift/ctrl/alt key(s) separately. (Making a Dvorak keyboard from a QWERTY, for example, back in DOS days.) That's more assembler than C code, so don't worry about it. What whitetiger0990 has are the codes the robot controller gives you for joystick output. Normally joysticks and keyboards don't mix, so I too am curious on what you may be trying to do. ____________________________ "If it weren't for electricity we'd all be watching television by candlelight." - George Gobel |
Yup that's what I was looking for. I'm trying to make it so when I go forward on the joystick it will automatically press the arrow key that corresponds with the direction. I'm toying with this for online games and such that use the arrow keys.
| Keyboard Question | Molten | Chit-Chat | 11 | 10-02-2008 12:49 |
| Joystick Output Values? | compwiz2008 | Programming | 5 | 17-01-2008 22:40 |
| Question about CMUCAM servo output | itsme | Programming | 9 | 13-01-2007 17:44 |
| joystick buttons and a quick question | h0x4r | Programming | 2 | 17-02-2005 00:18 |
| Dashboard Output Question | jnossen | Technical Discussion | 5 | 02-02-2002 19:52 |
