pic: 1565 Linkage Troubles
Re: pic: 1565 Linkage Troubles
Oooo, Oooo. Mr. Cotta, Mr. Cotta.
(Sorry, I'm probably to old for most of you to get the reference.) Is it the "S" shaped link bar?? |
Linkage arm is bent.
Linkage bolt is not perpendicular to the linkage arm. Also, is it just me or does it look like the entire linkage piston is unseated? |
Flat bars aren't very strong in compression...maybe try angle next time?
Next time we will make sure that the outside frame doesn't get shifted (more bracing fixed the problem completely) lol. The flat stuff is strong enough, and only in that rare occasion would angled be nessacary. Unfortnatly angled pieces take up a lot of space. we may dimple them for next year though (raise the middle, so it is very slightly concave or convex) JeeseK good work on the bolt!! The bolt is out of alignment because the two bars connected to it are also bent (just not nearly as badly as the long link ) |
#7
You could probably get away with cutting the flange off the angle for several inches at each end. The dimpled center idea is good too, if you can figure out an easy way to do it. This is pretty common in linkages on real life machines (for example the flat bar that connects the inner door handle in a 1950s chevy).
#8
In our shop we have what looks like an ancient machine that will put a big long dimple down the middle of sheet metal and such, a bead roller. we used it on paper thin and flimsy lexan in '06 and it seemed to work really well at giving some added strength.
#10
Ya that looks pretty nasty. I wish I had a picture of the 3/8ths aluminum bolt we broke in half at champs and the welds that broke off our elevator bearing holder tabs the very first qualification match of the day on Friday. Quite funny stuff looking back at it now, not so much at the moment though. I hope you guys got everything up and running and were able to over come that little bump it looks like you took.
-Good luck Drew |
#11
we managed to fix the linkage in about 10 mins lol flat bar is plentiful so we just made a new one!!
#12
Bummer, that is a real problem....
| pic: 1565 Twitch the missing Linkage Ball hold | T3_1565 | Extra Discussion | 13 | 30-03-2008 14:00 |
| pic: 1565 Twitch the missing Linkage Underbelly | T3_1565 | Robot Showcase | 12 | 17-03-2008 13:58 |
| pic: 1565 Linkage Drive System | T3_1565 | Extra Discussion | 10 | 13-02-2008 15:44 |
| pic: 1565 Extended Version | T3_1565 | Extra Discussion | 5 | 04-02-2007 22:20 |
| pic: 1565 Compact Version | T3_1565 | Extra Discussion | 2 | 04-02-2007 20:37 |
