Go to Post A well learned individual knows themselves and how to collect and use the tool of knowledge. - techhelpbb [more]
Unread 25-04-2008, 22:04
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
Ribbon cables
so i have been trying to add pwm cables to my robots, but i just cant seem to get it right. i made the connectors, pin groups, pwm library wire, but it isnt quite working. im not sure why there is a massive red slash in the middle and why it is not making all three wires, only two.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 25-04-2008, 22:23
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Ribbon cables
Increase the width and see what happens. My guess is that Inventor doesn't think it can fit three leads onto the ribbon.
Unread 26-04-2008, 04:21
Aceanuu's Avatar
Aceanuu Aceanuu is offline
FRC #1477 (Northside Roboteers)
Aceanuu will become famous soon enoughAceanuu will become famous soon enough
Re: Ribbon cables
Actually, as far as I'm aware, thats the way it works. It only does the two end cables and a swath of a color in between. Frankly, people dont usually need a photorealistic render, so the two round cables on the end and the filler in between do just fine for a program like inventor. In my robot, I did make one instance of a ribbon cable that was 4 cables of different colors... but I really just made two ribbon cables and put them next to each other... so you can't tell.
So you aren't doing it wrong, that is simply how inventor does it.
Ribbon cable Pneumaticsman Electrical 4 08-02-2008 20:00
Ribbon Cable emusteve Electrical 6 13-01-2006 16:33
Ribbon cable sources. Rickertsen2 Electrical 9 19-01-2004 16:23
Ribbon Cables for Digital Input Caleb Fulton Electrical 5 06-02-2003 08:39
