Go to Post That sound you hear is a student on the mechanical team trying to get out of the shipping crate you closed too early. - Al Skierkiewicz [more]
Unread 28-04-2008, 14:59
jax1488's Avatar
jax1488 jax1488 is offline
The Northern Chicken Wizards
AKA: jack stone
FRC #0522 (Robo Wizards)
jax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to all
Send a message via AIM to jax1488 Send a message via MSN to jax1488 Send a message via Yahoo to jax1488
hey got a tech question about AM Trannys
does anyone know the final output RPM of an andymark tranny? of high and low gear?
i cant find any information online
"i dont like it, but i cant tell u why!" -"Dearrin"
2006 "aim high" national championship champions. (ty 296 and 217, NOTHERN CHICKEN WIZARDS... UNITE!)
2006 Greater Toronto Regional Chairman's Award
2004 N.Y.C. Regional Champion
2004 N.Y.C. GM Industrial Design
2004 N.Y.C. Daimler Chrysler Team Spirit
2003 N.Y.C. Regional Champion
Unread 28-04-2008, 15:01
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: hey got a tech question about AM Trannys
Which transmission you trying to find information on?
They sell several two speed transmissions.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 28-04-2008, 15:05
jax1488's Avatar
AKA: jack stone
servo shifter (gen 2)
with 2 small cims a piece.. i dont understand how to do the math
Unread 28-04-2008, 15:18
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Small CIM has a free speed of about 5300 rpm - however at 40 amps it is more like 3800 rpm.
Therefore in high gear that would be between 404 rpm (40 amp) and 564 rpm (2.5 Amp).
Low gear would be between 158 rpm (40 Amp) and 221 rpm (2.5 Amp).
The speeds are the same whether you have one or two CIMs. Having two Cim's just doubles the torque
Unread 29-04-2008, 21:59
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
servo shifter (gen 2), with 2 small cims a piece.. i dont understand how to do the math
All... looking through this thread, I really don't think that the original question was answered.
On the AM Servo Shifter page, these gear reductions are listed:
Gear Reduction
Low: 10.67:1
High: 4.17:1
Difference between Low and High: 2.56:1
Here is my description on how to "do the math", in a nutshell:
A CIM motor has a free speed of about 5200. If two CIM motors are installed on an AndyMark gearbox, then the top speed (motor rpm) that you will be able to get is about 4300 or 4400. Let's call this the "top working speed". (The difference between the free speed and this working speed is because of efficiency losses, inertia, and friction in the mechanical system)
Using 4400 rpm as this top working speed, here are the resulting low and high speeds for an AM Shifter (servo or pneumatic):
Low: 412 rpm (4400 / 10.67)
High: 1055 rpm (4400 / 4.17)
This is the output rpm at the sprockets on the AM Shifter. Further reduction can be made, of course, with the sprockets on the wheels and the size of the wheel. Keep in mind that the smaller your wheel is, the less reduction you need to go an optimal speed.
Now... regarding the roll pins shearing and other stuff, I will make another post. Tyler's post is right on the money. However, the Super Shifter did see more vibration this year than the AM Shifters experience. The AM Shifters all use chain drive. The Super Shifters can be used in direct drive situations. Because of this, the Super Shifters experience more vibrational loading.
Like previously noted by Tyler and Travis, you must use stops on the cylinder so that the dog is positioned into place and held there, as opposed to continually pushing the dog into the gear. For servo shifting, this burns up the servo. For pneumatic shifting, this wears down roll pins.
Also, shifting at 40 psi seems to work the same as 60 psi. I do not suggest using 25 psi unless you are only shifting when not pushing against anyone. Also, servo shifting does not work when pushing against anyone. Servo shifting pushes with about 5 pounds of force. Pneumatic shifting at 60 psi puts out 33 lbs of force. Regulating the pressure down to 40 psi still gives 22 pounds of shifting force. This is still much stronger and more responsive than servo shifting.
Once again, I will say that I DO NOT RECOMMEND servo shifting, unless a team has absolutely no need for pneumatics on their robot.
We have some improvements listed for these gearboxes:
gearing options - other ratios (Toughbox, Stackerbox, maybe Shifters)
adding an encoder to the Toughbox and AM Shifter
higher strength roll pins
Longer output shaft for Toughbox
A better way to servo shift
Optional aluminum side plates for AM Shifters
These are in order of importance and priority. There may be more. We have a "to do" list on our main whiteboard at AndyMark central that is about 50 items long.
I hope this helps.
Sincerely,
Andy
Unread 28-04-2008, 15:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
From the AndyMark web page describing the Supershifter:
STANDARD GEARING (this is what is shipped with a Super Shifter order)
Ratio between High and Low gears: 2.56:1
FINAL STAGE, w/ 45:20 GEARS:
Low Gear: 24.0:1
High Gear: 9.4:1
so just divide motor rpm by the gear ratio for low and for high and you'll get your answer. Of course, if you're using a different AM transmission you'll need to get the numbers for that one.
Unread 28-04-2008, 15:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Low Gear: 24.0:1
High Gear: 9.4:1
Keep in mind, though, that your motors operate at less than the free-speed under load.
--Madison--
...down at the Ozdust!
Unread 28-04-2008, 17:19
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Low Gear: 24.0:1
High Gear: 9.4:1
just another note, the supershifters came with a 48:17 final stage option also.
Unread 28-04-2008, 18:12
AdamHeard's Avatar
Lead Mentor
the output RPM of the gearboxes isn't *that* helpful of a figure.
If you are try to estimate a drive's performance, download JVN's mechanical design calculator from the whitepapers; Input your motor and gearbox specs (for efficiency, do .9ish for each spur/sprocket reduction.) and it will provide you some nice data on velocity, current draw, etc...
Unread 28-04-2008, 18:19
Adam's right, output RPM of the gearboxes might not help that much.
For example, it is ridiculously easy to change it. Just change the output sprocket or the one on the other end of the chain. Your wheel spins at a different speed.
Or, the final output to the wheels might be different from what it's supposed to be. (Note to self--Next time mecanums are used, reverse the Toughbox-to-wheel chain-run sprockets.)
Unread 28-04-2008, 21:17
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
speaking of AM supershifters (gen 3)
did anyone have a problem with the roll pin in the shifter coupling breaking? (the thing that attatches the piston to the dog gear shaft)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 28-04-2008, 22:04
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
What pressure are you shifting at? We sheared off that roll pin in one of our Gen 2 shifters last year. Shifting these things at 60PSI is a big no-no. When I asked Andy Baker, I seem to remember him saying that 25PSI is more than sufficient. Though I guess it shouldn't be surprising that applying that much force to one of those pins would wreck it (as anybody who had difficulty assembling Toughboxes this year will tell you), it'd be a nice warning to have in the documentation.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 28-04-2008, 22:46
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
we downed the psi to 40 after breaking like 10 pins
25 though? that seems a little low. i wonder if the solenoid will even shift at 25 psi... doesnt it take 30 before it does anything?
RPI 2012
BREAKAWAY
Unread 28-04-2008, 23:03
CraigHickman
Posts: n/a
We didn't use roll pins in our transmissions, in order to avoid the breakage issue. Actually, due to a flaw in dimensioning, we ended up with two different hole sizes. As a result, we used steel nails as our shifting pins. It seemed pretty ganky to us, but it worked really well. Plus, it was pretty cool to tell people that our robot was held together by nails.
Back on topic, we ran our shifting pneumatics at about 35ish, and never had any issues.
Unread 28-04-2008, 23:23
Billfred's Avatar
Billfred Billfred is offline
Strange, we never had any roll pin issues while shifting at 60 PSI. (The pressure issue is news to me--I'll send some kids after the matter at the next meeting.)
I'll second the endorsement for JVN's calculator; our last two robots have been greatly improved for its use.
hey, stupid question but... fallen751 Programming 16 24-01-2007 17:49
Got an question on start postion of the robot? DanTheRobotMan Rules/Strategy 9 12-01-2006 17:32
Tech Question About CAD and RP indieFan Chit-Chat 2 23-07-2004 12:35
Hey guys I got the Best Idea Dima Rules/Strategy 18 20-01-2003 19:52
